Finding the Equation of a Parabola with a Given Focus and Directrix
  • Context: Undergrad
  • Thread starter Thread starter Claire84
    Parabola
The discussion revolves around finding the equation of a parabola given its focus at (1,1) and a directrix defined by the equation x + y = 0. Participants explore the mathematical derivation of the parabola's equation and discuss the properties of tangents to the parabola, including a specific case involving the relationship between two tangent lines.
  • One participant describes their approach to finding the parabola's equation by equating the distances from an arbitrary point to the focus and the directrix, resulting in the equation x^2 + y^2 - 2xy - 4x - 4y + 4 = 0.
  • Another participant confirms the correctness of the derived equation.
  • Participants discuss the gradient of the tangent line ax + by + c = 0, with one participant calculating it as -a/b and questioning the meaning of the reciprocal.
  • Some participants propose that the symmetry of the parabola implies that if (u,v) is on the curve, then (v,u) is also on the curve, leading to a discussion about the tangents at these points.
  • There is a suggestion to find the intercepts of the tangent lines and relate them to the original tangent line's equation.
  • One participant expresses uncertainty about how to find where the slope of the parabola equals a specific value, seeking clarification on the process.
  • Another participant provides a detailed method for showing that the two tangent lines are related, involving the slopes and intercepts derived from the parabola's equation.
  • There is a discussion about the gradients at points (u,v) and (v,u), with one participant questioning their understanding of the reciprocal relationship between these gradients.
  • One participant expresses frustration over their calculations and seeks reassurance about their approach.
While some participants agree on the correctness of the parabola's equation, there is no consensus on the best method to demonstrate the relationship between the tangent lines. Various approaches are proposed, and some participants express confusion or uncertainty about specific steps in the reasoning.
Participants mention various assumptions and conditions related to the gradients and intercepts of the tangent lines, as well as the symmetry properties of the parabola. There are unresolved mathematical steps and dependencies on the definitions of terms used in the discussion.
Claire84
I've just finished my pure h/work but the final question has me a bit baffled because in lectures we've only been dealing with parabols where the focus is like (a,0) and the directrix is just y=k where k is a real number. However, for this question we've to find the eqt of the parabola whose focus is at the point (1,1) and whose directrix has the eqt x + y = 0
I've drawn it out so that I've chosen an arbitrary point (x', y') and then worked out the distance between this point and the focus to be the square root of (x' - 1)^2 + (y' - 1)^2
For working out the distance between the point and the directrix I've got the modulus of (x' + y')/sqrt2
I've then set these two equal to each other by the definition of the parabola and got x^2 + y^2 -2xy -4x- 4y +4=0 as the eqt of the parabola. Can someone confirm if hi is is correct or not?
The second part of the question is that if the line ax + by+ c =0 is a tangent to the parabola, then show that the line bx + ay +c=0 is also one of its tangents. I'm really not sure how to go about this one. I thought maybe you could differentiate the eqt of the parabola and then diferentiate the eqts of the tangents and work from there, but it's going pear-sharped. Can anyone point me in the right direction? Thanks!
Yes, the equation looks right
as for the second.
find the tangent to the curve at some point in a general form. let the equation be ax+by+c=0. the gradient of this line is what, in terms of a and b? now find if there is a point on the curve where the tangent has gradient the reciprocal of what yo'uve found. what does that tell you about the equation of the tangent here? How much like the first equation is it?
I got he gradient of ax+by+c=0 to be -a/b . What do you mean by the reciprocal?
if you want a slicker way of doing it:
the equation is totally symmetric in x and y. if (u,v) is on the curve, so is the point (v,u)
What is the tangent vector at (u,v) (and at (v,u))
hence what are the (vector) equations of the tangent lines
I mean, what is the gradient of the line bx+ay+c=0?
it's -b/a
which is the reciprocal of -a/b
(reciprocal of x is 1/x)
find the two points on the curve whose tangents have these slopes. what are the intercepts?
Hang on the reciprocal of -a/b would be -b/a, right? And that's the graident of bx + ay+c=0 So am I supposed to set these gradients equal the eqt of the parabola differentiated with respect to x? It's just easier for me thais way because I've a fear of vectors being used like that after having a v.mad Russian lecturer last semester who was barmy about vectors! ;)
Let (u,v) be a point on the parabola. Find the gradient at (u,v) let this be r
then the equation is y=rx+c of the tangent for some c.
you want to show that there is a point on the curve whose tangent has equation
y=x/r+d
first find where on the curve the slope is 1/r
now find the intercepts c and d. nor rearrange
ry=x+rd,
so you need rd=c
When you say intercepts you mean the y-axis intercepts?
y=x/r+d
How do I do that? Would I set 1/r equal to the gradeint of the parabola?
yes, intercept is y-axis intercept, and finding where the slope is 1/r means setting the gradient of the parabola to be 1/r.
So in this instance I'm actually setting it to be -b/a and seeing what I get out of it?
That would depend on where you are starting from.
1. If you are presuming that ax+by+c=0 is a tangent line at the point (u,v) you must demonstrate there is a point where the gradient is -b/a, for then there the tangent line has equation
y=-bx/a+d,
rearranging we see
bx+ay-bd=0,
you must now find -bd and show it is c.
How you do that is up to you.
2. Start from scratch. Throw away what you've written so far.
Find the equation of the tangent line at (u,v) in terms of u and v.
write it in the form y=rx+c
now find where the parabola has slope 1/r, there the tangent line has equation
y=x/r+d
rearrange and prove what the question asked you to do.Pick one of these methods and stick to it. Tell me which you are doing, where yo have got to with it.
Ok, here's my solutionwe see that the slope of the parabola is given by
[tex]\frac{dy}{dx}=\frac{2+y-x}{y-x-2}[/tex]from which we see that the gradient at a point (u,v) is the reciprocal of the gradient at at the point (v,u) which also lies on the parabola by the symmetry of x and y in the equation defining the parabola
assume this is not zero or infinity
So the tangents are y=rx+c and y=x/r+d resp, for some c and d.
we know that the lines go through the points (u,v) and (v,u) resp so we see
v=ru+c and u=v/r+d so that c = rd
hence
y=rx+c is a tangent line iff ry=x+c is a tangent line, as required (we may divide through the original equation as in the question by a, assuming a is not zero).
The case a=0 is left to you.
y=-bx/a+d,
rearranging we see
bx+ay-bd=0,
Okay, this is the one I guess I went with. I set -a/b equal to the eqt of the parabola and in the end I got the following-
y(b+a)= x(b+a) +2b - 2a
so the y-intercept is 2b -2a
Then I set -b/a equal to the eqt of the parabola and got the following-
y(a+b)= x(a+b) -2a + 2b
so the y-intercept is -2a + 2b
Since we're told that the eqt of the tangent is ax + by + c=0 and the one we're trying to show is bx +ay +c =0, we can rearrange these both so that we have-
c = -ax -by (for the eqt we are told)
c = -bx -ay (for the eqt we are trying to show)
From what was previously worked out-
c= 2b-2a for the eqt we know and
c= -2a +2b for the eqt we're trying to show
So from these you could see that x=2 and y=-2 for both.
Now I've no idea why I even went down that path. Think I'll just concentrate on your solution!
You see when you say the gradient of the point (u,v) is the reciprocal is the gradient at the point v,u how does that work?
The grad at u,v is (2 + v -u) / (v - u -2)
And the grad at v,u is (2 + u - v )/ (u-v -2)
So its reciprocal would be-
(u - v - 2) / (2 + u - v)
Spo I'm not sure where I've gone wrong here. Sorry.[b(]
multiply top and bottom in the last line by -1, and you get what you want.
Thanks, I'm so stupid for not seeing that. I fear my brain has shut down after too much Maths this weekend.
  • · Replies 44 ·
  • · Replies 21 ·
30K
