Nuclear Power Explained: Harnessing Neutrons for Energy
The discussion centers around the concept of nuclear power, specifically how neutrons from materials like UO2, U, and PuO2 are utilized for energy generation. Participants explore various aspects of nuclear reactors, including their operation, the underlying physics, and the relevance of quark interactions in nuclear reactions.
  • Homework-related
  • One participant requests a simple description of nuclear power and how neutrons are harnessed for energy.
  • Another suggests using online resources and libraries for research, implying that self-directed learning is important.
  • A participant mentions that most nuclear power plants generate heat to boil a liquid for turbine operation.
  • One participant expresses interest in the quark model and its relevance to nuclear reactors, questioning the necessity of understanding quark interactions for sustainable nuclear reactions.
  • Another participant argues that the fission process relies on the binding energy of nucleons in fissile nuclei, stating that quark models are not useful for understanding or simulating nuclear reactors.
  • A participant emphasizes that nuclear energy transforms into thermal energy, which is then converted into mechanical energy and ultimately electrical energy.
  • Several participants provide links to external resources for further reading on nuclear power and reactors.
  • One participant humorously suggests that the only unsolved problems in fission reactors relate to practical issues like plumbing and waste disposal.
Participants express varying degrees of understanding and interest in nuclear power, with some focusing on practical aspects while others delve into theoretical models. There is no consensus on the relevance of quark interactions to nuclear reactor operation, indicating a divergence in viewpoints.
The discussion includes references to various models and theories, but the applicability of quark interactions to nuclear power remains unresolved. Participants also highlight the importance of empirical data in nuclear physics, suggesting a reliance on experimental results over theoretical modeling.
This discussion may be useful for individuals interested in nuclear power, nuclear engineering, and the underlying physics of nuclear reactions, as well as those seeking resources for further study in these areas.
the_Shadow_13
Hi, I was wondering if anyone could give me a simple description on what nuclear power is. I.e. how the neutrons from UO2/U/PuO2 are harnessed for power?
Also, if anyone knows any useful links for information on nuclear power, different types of ractors etc, then it will be very useful :smile:
Are you familiar with Google? Just type it in and away you go! I will give you www.nrc.gov[/url] and [url]www.aecl.ca[/URL] as sources (since they are credible), but you should do the research on your own since that's how you learn. You can also go to a library to look up this stuff in [B]books[/B]. I'm assuming this is schoolwork?
See if that helps get you started.
Most nuclear power plants use the heat generated by the reactor to boil a liquid to run a turbine.
I have a deeper question. The model for a sustainable nuclear reaction does not require knowledge of the quark interactions during this process. I would like to look into the quark model for a nuclear reactor. Can anyone point me in a good direction without requiring to learn how to calculate color charge interactions?
I would like to point to the nuclear engineering forum we also have on PF. Nuclear reactors and related physics is its main subject.
As to using quantum chromodynamics (the theory of quarks and color) to do low-energy nuclear physics, good luck :biggrin:
No, seriously, experiment is much and much more in advance over ab initio modelling. And even phenomenological modelling in nuclear physics is experiment-driven (and not much more than curve fitting).
The generation of nuclear energy does not involve quarks. The fission process is based on the binding energy of the collection of nucleons we call a nucleus, specifically fissile nuclei such as U-235, Pu-239 (and 241), U-233, and other heavier transuranics.
A quark model will not help understand or simulate a nuclear reactor. An appropriate core simulator and cross-section (or lattice) physics code will.
Meir Achuz said it in a nutshell. Nuclear energy transforms to thermal energy (heat = kinetic energy of atoms) which is tranported by a working fluid (coolant) either directly or indirectly (through another working fluid) to a turbine where it is transformed into mechanical energy, which drives a generator, which transforms the mechanical energy into electrical energy via a time varying magnetic field.
Berkeman gave a decent recommendation
and i'd add - http://hyperphysics.phy-astr.gsu.edu/hbase/nucene/fission.html
http://www.world-nuclear.org/how/fuelcycle.html
http://www.world-nuclear.org/how/npreactors.html
"I have a deeper question. The model for a sustainable nuclear reaction does not require knowledge of the quark interactions during this process. I would like to look into the quark model for a nuclear reactor. Can anyone point me in a good direction without requiring to learn how to calculate color charge interactions?"
The only unsolved problems for fission reactors are plumbing, Murphy's law, and waste disposal and monitoring.
  • · Replies 20 ·
  • · Replies 32 ·
