What is the Resultant Force When Sitting and Other Physics Queries?
  • Thread starter Thread starter future_vet
    Physics
The discussion revolves around various physics problems, including the resultant force experienced when sitting on a chair, the behavior of a moving object in the absence of external forces, and the coefficient of static friction on an inclined plane.
  • Participants attempt to identify the direction of forces acting on a person sitting on a chair and question the resultant force. They also discuss the motion of an object without external forces and explore the relationship between angle and static friction on an incline.
Some participants have provided clarifications and corrections to initial answers, while others are questioning the validity of their responses. There are indications of productive dialogue regarding the concepts of force and motion, but no consensus has been reached on all points.
Participants are working within the constraints of homework questions, which may limit the information provided and the assumptions made in their reasoning.
future_vet
When you sit on a chair, the resultant force on you is ..?
Down, because of gravity?
In the absence of an external force, a moving object will:
stop immediately
slow down and eventually come to a stop MY ANSWER
go faster and faster
move with constant velocity
An object is placed on an inclined plane. The angle of the incline is gradually increased until the object begins to slide. The angle at which this occurs is theta. What is the coefficient of static friction between the object and the plane?
tan(theta)
That's what I understood, but I need to make sure...
Thanks!
All of your answers are incorrect. Try again, draw force diagrams and really think these problems through.
For the first one, the force on the chair is down, but the force on me is up... Would this be correct?
For the second one, I reviewed the laws, and I would say that the velocity would stay constant (unless some external force came into play). Would this be correct?
Yes, that's better. For the second question, start with F=ma.
EDIT -- And I believe that your answer for the 3rd one is correct, [tex]\mu_s = tan( \Theta )[/tex]
Are you absolutely sure my last answer is incorrect?...
The Prenhall website has the same question. I entered an answer other than tan to make sure, and I got:
An object is placed on an inclined plane. The angle of incline is gradually increased until the object begins to slide. The angle at which this occurs is θ. What is the coefficient of static friction between the object and the plane?
Your Answer:
sin θ
Correct Answer:
tan θ
You mean that if F doesn't change, and m doesn't change, a will be constant?
That is correct.
No, I mean that if there is no external force, the acceleration is zero. And you correctly inferred that this means the velocity is constant.
Thank you!
the resultant force on me is mg upward where m is my mass angd is acceleration due to gravity
in absence of external force body moves with constant velocity
  • · Replies 16 ·
