Finding resistance using a series and parallel circuit?
The discussion revolves around determining the resistances R1 and R2 of two resistors connected in both series and parallel configurations to a 12.0V battery, with given currents of 2.00A in series and 9.00A in parallel.
  • Mixed
  • Participants explore the relationships between resistances in series and parallel circuits, noting that the same resistors are used in both configurations. Some express confusion about how to proceed with the calculations, while others suggest drawing circuit diagrams and reducing resistances to equivalent circuits.
There is an ongoing exploration of the problem, with some participants providing hints and guidance on labeling variables and setting up equations. However, explicit consensus on the approach or solution has not been reached, and some participants express uncertainty about their calculations.
Participants question the assumptions regarding the equality of resistances in different configurations and the implications of the given voltage and current values. There is also a mention of potential confusion in labeling variables related to voltage and current.
shaffeb
:Two resistors have resistances R1 and R2. When the resistors are connected in series to a 12.0V battery, the current from the battery is 2.00A. When the resistors are connected in parallel to the battery the total current from the battery is 9.00A. Determine R1 and R2.
: V=IR Ohms Law
I know that R1 and R2 are the same resistance in both circuits, or R1 and R2 in series = R1 and R2 in parallel.
I also know that the current remains the same in series but changes in the parralel circuit and that the voltage is not constant in series but the same voltage is applied over the resistors in a parallel circuit.
V=I(R1+R2)
R1+R2=V/2.00A=12.0volts/I
Thus V/2.00A=12.0volts/I
I get confused at this point and am not quite sure how to proceed in finding V or I and thus solve for R1 and R2.
: V=IR Ohms Law
V=I(R1+R2)
You're given V and i in this problem. Draw circuits for both cases of series and parrallel circuit. From there you can see how to solve it, then wite out the equations. Hint: Reduce the resistances to one equivalent circuit for both cases. Also why do you think R1 = R2?
I didn't mean to say that R1 = R2 I just meant that R1 and R2 in the series must equal R1 and R2 in the parallel.
Is it ok to assume that V/2.00 A = 12.0 Volts/I since R1 in series is equal to R1 in parralel and R2 in series equals R2 in parallel?
Yea that works, and I see what you're trying to do. The method I posted in my first post would not need to find V and I.
Is it simple algebra from here or am I missing something? I keep getting nonsense answers. Thanks
Well I would be careful of the way you're labeling V and i. Like label it i1 and i2, for the currents going through R1 and R2 in the parallel circuit. Same thing for the voltages in the series circuit. Also post up what you have so far, so maybe someone else can help you out. :smile:
one resistance is 2 ohm the other one is 4 ohm.
For parallel:
R[tot]=V/I and (R[1]*R[2])/(R[1]+R[2]), therefore: V/I=(R[1]*R[2])/(R[1]+R[2])
For searies:
R[tot]= V/I and R[1]+R[2], therefore V/I=R[1]+R[2]
Now you have two unknown and two equations, isolate R[1] or R[2] from V/I=R[1]+R[2] and put into V/I=(R[1]*R[2])/(R[1]+R[2]), then one of the resistance is known and the otherone is easily found.
Hope this solves the problem
For parallel:
For searies:
:bugeye: :mad: What are you doing? You just gave him pretty much the entire solution to problem.
  • · Replies 24 ·
