Complex substitution into the equation of motion.
The discussion focuses on solving the equation of motion for a mass m in a rotating coordinate system, specifically under the condition where the external force F equals zero. The transformation from Cartesian coordinates to complex notation using z = x + iy simplifies the equation to a second-order ordinary differential equation (ODE): d²z/dt² + i2ω dz/dt - ω²z = 0. The solution to this ODE can be achieved through the substitution z = fe^(-iωt), confirming the validity of the transformation and the resulting dynamics.
  • Understanding of classical mechanics, particularly equations of motion.
  • Familiarity with rotating coordinate systems and angular velocity concepts.
  • Knowledge of complex numbers and their applications in physics.
  • Experience with solving ordinary differential equations (ODEs).
  • Study the derivation of the equation of motion in rotating frames.
  • Learn about the applications of complex numbers in physics, particularly in dynamics.
  • Explore methods for solving second-order ordinary differential equations.
  • Investigate the implications of angular momentum in non-inertial reference frames.
This discussion is beneficial for physics students, mechanical engineers, and anyone involved in dynamics and motion analysis in rotating systems.
ultimateguy
The equation of motion of a mass m relative to a rotating coordinate system is
[tex]m\frac{d^{2}r}{dt^2} = \vec{F} - m\vec{\omega} \times (\vec{\omega} \times \vec{r}) - 2m(\vec{\omega} \times \frac{d\vec{r}}{dt}) - m(\frac{d\vec{\omega}}{dt} \times \vec{r})[/tex]
Consider the case F = 0, [tex]\vec{r} = \hat{x} x + \hat{y} y[/tex], and [tex]\vec{\omega} = \omega \hat{z}[/tex], with [tex]\omega[/tex] a constant.
Show that the replacement of [tex]\vec{r} = \hat{x} x + \hat{y} y[/tex] by z = x + iy leads to
[tex]\frac{d^{2}z}{dt^2} + i2\omega\frac{dz}{dt} - \omega^2z=0[/tex].
Note, This ODE may be solved by the substitution [tex]z=fe^{-i\omega t}[/tex]
None.
I've calculated that [tex]-\vec{\omega} \times (\vec{\omega} \times z) = \omega^2 z[/tex].
As far as figuring out how [tex]-2(\vec{\omega} \times \frac{d\vec{r}}{dt}) -(\frac{d\omega}{dt} \times \vec{r})[/tex] gives [tex]i2\omega\frac{dz}{dt}[/tex] I'm lost.
I solved it. Turns out that [tex]-2(\vec{\omega} \times \frac{d\vec{r}}{dt}) = -2i\omega\frac{dz}{dt}[/tex] and since F = 0 then [tex]\frac{d\omega}{dt} = 0[/tex].
  • · Replies 26 ·
