Does X/Y Follow a Beta Distribution?
The discussion centers on the distribution of the ratio of two gamma-distributed random variables, specifically whether the ratio X/Y follows a beta distribution. Participants explore different aspects of this topic, including theoretical proofs and clarifications regarding related distributions.
  • Homework-related
  • One participant initially questions whether X/Y follows a beta distribution, noting that they found X/(X+Y) does follow a beta distribution.
  • Another participant corrects the first by confirming that X/(X+Y) is indeed the correct ratio that follows a beta distribution.
  • A different participant asserts that X/Y does follow a beta distribution under the condition that both gamma variables have the same second parameter, referring to it as the beta distribution of the second kind.
  • This participant provides a detailed derivation involving multivariate transformations to show how the distribution of U_1 = X/Y can be obtained, including the use of joint distributions and integration.
  • Several participants express a need for proofs regarding the beta distribution of X/(X+Y), with one participant mentioning the mean of the beta distribution as potentially relevant.
  • Another participant emphasizes the importance of understanding the relationship between gamma and beta functions in the context of the discussion.
There is no consensus on whether X/Y follows a beta distribution, as some participants argue for its validity under specific conditions while others focus on the ratio X/(X+Y) as the correct case. The discussion remains unresolved regarding the broader applicability of X/Y.
Participants note the importance of specific parameters and conditions under which the distributions are valid, as well as the need for proofs and deeper understanding of the relationships between the distributions involved.
This discussion may be useful for students and researchers interested in probability theory, particularly those studying the properties of gamma and beta distributions and their applications in statistical modeling.
jimmy1
If X and Y are gamma distributed random variables, then the ratio X/Y, I was told follows a beta distribution, but all I can find so for is that the ratio X/(X+Y) follows a beta distrinbution.
So is it true that X/Y follows a beta distribution?
Ok, I found the answer (just had a bit of a brain freeze!). It is X/(X+Y), and not X/Y
X/Y does follow a beta distribution! (Assuming they have the same second parameter. This is very important). It's called the beta distribution of the second kind with parameters alpha_x and alpha_y. The F distribution is simply b*X/Y where b>0.
I'll show you why X/Y is called the beta distribution of the second kind.
Suppose X~[tex]\Gamma(\alpha_1,\beta)[/tex] and Y~[tex]\Gamma(\alpha_2,\beta)[/tex], X and Y independent. What is the distribution of [tex]U_1=\frac{X}{Y}[/tex]?
Now this is a multivariate transformation, (http://www.ma.ic.ac.uk/~ayoung/m2s1/Multivariatetransformations.PDF see here if you don't know how to do these), so we will use [tex]U_2=Y[/tex] as an auxillary equation.
So, [tex]g_1(x,y)=x/y[/tex] and [tex]g_2(x,y)=y[/tex] where x,y are positive reals (because they come from a gamma distribution) now it should be clear to see that [tex]g_1^{-1}(x,y)=xy[/tex] and [tex]g_2^{-1}(x,y)=y[/tex]. Note how g_1 and g_2 have range (0,+infty).
Therefore, [tex]f_{(U_1,U_2)}(u_1,u_2)=f_{(x,y)}(g_1^{-1}(u_1,u_2),g_2^{-1}(u_1,u_2))|J|[/tex]. As an exercise you can show that [tex]|J|=u_2[/tex]
Since X and Y are independent [tex]f_{(X,Y)}=f_X f_Y[/tex]
Now [tex]f_{(U_1,U_2)}(u_1,u_2)=f_x(u_1u_2)f_y(u_2)u_2=\frac{e^{-\frac{1}{\beta}(1+u_1)u_2}u_1^{\alpha_1-1}u_2^{\alpha_1+\alpha_2-1}}{\beta^{\alpha_1+\alpha_2}\Gamma(\alpha_1)\Gamma(\alpha_2)}[/tex]
(I have done some simplifying)
Now, we don't want the pdf of (U_1,U_2) we want the pdf of U_1, so we integrate over the joint to get the marginal distribution of U_1.
[tex]f_{U_1}(u_1)=\frac{u_1^{\alpha_1-1}}{\beta^{\alpha_1+\alpha_2}\Gamma(\alpha_1)\Gamma(\alpha_2)}\int_0^{+\infty}u_2^{\alpha_1+\alpha_2-1}e^{-\frac{1}{\beta}(1+u_1)u_2}du_2[/tex]
But the integral is just a gamma function (after we change variables). So this means that [tex]\int_0^{+\infty}u_2^{\alpha_1+\alpha_2-1}e^{-\frac{1}{\beta}(1+u_1)u_2}du_2=\frac{\Gamma(\alpha_1+\alpha_2)\beta^{\alpha_1+\alpha_2}}{(1+u_1)^{\alpha_1+\alpha_2}}[/tex].
Plugging this in we get [tex]f_{U_1}(u_1)=\frac{\Gamma(\alpha_1+\alpha_2)u_1^{\alpha_1-1}}{\Gamma(\alpha_1)\Gamma(\alpha_2)(1+u_1)^{\alpha_1+\alpha_2}}=\frac{u_1^{\alpha_1-1}}{\beta(\alpha_1,\alpha_2)(1+u_1)^{\alpha_1+\alpha_2}}[/tex]
So there we go! U_1=X/Y is distributed as that. Now why is this called a beta distribution of the second kind? If you do some transformations you should see that [tex]\beta(\alpha_1,\alpha_2)=\int_0^1x^{\alpha_1}(1-x)^{\alpha_2-1}dx=\int_0^{+\infty}\frac{x^{\alpha_1-1}}{(1+x)^{\alpha_1+\alpha_2}}dx[/tex]
I hope someone finds this interesting ;0
Hello!
I desperately need a proof of the fact that x/(x+y) has a beta distribution.
alexis_k said:
Hello!
The mean of the beta distribution is [tex]\mu=\frac{\alpha}{\alpha+\beta}[/tex]. Does this help you?
Edit: Look up the PDF and the MGF of the beta distribution. I assume you know the relationship between the gamma and beta functions. By the way, just saying x/(x+y) doesn't mean much by itself. I'm assuming it's relevant to the ratio of two independent gamma distributions.
  • · Replies 30 ·
