How Do You Calculate Xav, (X^2)av, and deltaX for a Simple Harmonic Oscillator?
The discussion revolves around calculating the average position (Xav), the average of the square of the position ((X^2)av), and the uncertainty in position (deltaX) for a simple harmonic oscillator using its ground-state wave function.
  • The original poster attempts to use the normalization constant and the wave function to perform integrals but questions whether this approach will yield Xav. Participants suggest that inserting x into the integral is necessary for finding Xav.
Participants are engaging in clarifying the steps needed to compute the required averages and are discussing the normalization of the wave function. There is a focus on ensuring the correct application of the wave function in the integrals.
There is an emphasis on the normalization of the wave function and the need for clarity in the mathematical steps involved in the calculations. The original poster expresses uncertainty about their approach.
GreenLRan
Use the ground-state wave function of the simple harmonic oscillator to find: Xav, (X^2)av and deltaX. Use the normalization constant A= (m*omegao/(h_bar*pi))^1/4.
deltaX=sqrt((X^2)av-(Xav)^2)
wavefunc=A*e^(-ax^2) ?
I'm not sure if I'm on the right path, but I started out by plugging in A and doing the integral of the wavefunction. My question is... does doing this give me Xav? If not, how would I go about solving this problem?
If you plug the right A in and do the integral of [tex]\psi^* \psi[/tex] you should get 1. It's normalized. Getting <x>=Xav? requires inserting an x into the integral.
[tex]<f(x)>=\int \psi^*(x) f(x) \psi(x) dx[/tex]
Of course, you know you need to use Psi^2.
I said that in a pretty sloppy way. I've edited the post to clarify.
