Why does an airplane perform a loop?
  • Thread starter Thread starter jernejk
    Airplane Loop
The discussion centers on the mechanics of why an airplane, specifically a glider, performs a loop. Participants explore concepts related to aerodynamics, lift generation, control surfaces, and the dynamics of flight in a vertical maneuver. The conversation includes theoretical considerations and practical implications for RC airplanes.
  • One participant describes a scenario involving a glider in a vertical dive, suggesting that lift acts parallel to the horizon despite the dive.
  • Another participant challenges the assertion that lift can be produced without elevator input, emphasizing the role of control surfaces in managing pitch and angle of attack.
  • Concerns are raised about the interpretation of center of mass, with clarification that it is a fixed property of the airplane, not changing during flight.
  • There is a discussion about the relationship between elevator input and pitch stability, with some arguing that the elevator is crucial for controlling the loop while others suggest it complicates the explanation.
  • One participant proposes that the mechanics of a loop can be simplified to the effects of elevator deflection and airflow, questioning the need for complex explanations involving center of gravity and airfoil shape.
  • A later reply discusses the necessity of adjusting elevator input during a loop, noting that different flight conditions affect the required control inputs.
Participants express differing views on the mechanics of looping, particularly regarding the role of elevators and the interpretation of lift and center of mass. There is no consensus on the explanations provided, and multiple competing perspectives remain throughout the discussion.
Limitations include varying assumptions about the stability of the airplane, the definitions of lift and angle of attack, and the specific conditions under which the glider operates. The discussion does not resolve these complexities.
jernejk
Dear all,
I'm a RC-airplane pilot with basic understanding of physics.
Recently I've been studying basic aerodynamics and I think I understand the basics.
However, I don't entirely understand why an airplane performs a loop and I can't find any references about it. Here's my current breakdown:
- for practical reasons, let's have a glider in a vertical dive
- nil wind
- we'll assume that the glider is flying at terminal velocity, so that weight and drag are neutral
My understanding of the situation:
- resultant of weight and drag is zero
- the wings still produce lift, perpendicular to the relative wind, so the lift vector is parallel to the horizon
- there is no opposite force to the lift
What happens (in a very short time frame, of course):
- the lift starts pulling the airplane
- center of mass moves further down and to the side (due to lift)
- the movement perpendicular to the wings generates drag on the horizontal tail, which in turns generates troque an rotates the plane over pitch axis
- because of this rotation, the airplane doesn't change the angle of af attack
- at the end of the time frame the situation is exactly the same as at the beginning, so here we go again.. and again.. and we perform a loop! (I know, the weight vector changes the direction and it needs to be accounted for)
Are my assumptions correct? Could someone provide accurate information?
TIA
Jernej
Why? This is not necessarily true, of course, since an airplane can be stable in a dive if it wants to. The elevators control pitch/angle of attack to cause the wings to produce lift. In the idealized case where 0 angle of attack is defined at 0 lift, there is no lift without input from the elevators (common with aerobatic planes anyway).
The center of mass of a physical object of constant physical shape is a physical property of the object. It does not change.
No. The control input at the elevators is what rotates the plane. This must be true, otherwise the plane will be pitch unstable (caveat: many fighter airplanes are pitch unstable). Since the CoG is in front of the center of lift, the lift from the wings acts against the elevator input to try to reduce the angle of attack.
Additionally, since the elevator increases the angle of attack by producing negative lift, its own effectiveness drops as the angle of attack increases.
No - see above.
For this example, let's say that our glider has a simple clark y airfoil, which produces lift at 0 aoa. 0 aoa=0 lift for symetric airfoil, which is considered good for aerobatics but I don't think it's considered "ideal".
Of course. What I meant is that the center of mass (in rc we just call it CoG) moves relative to the ground, not relative to the airplane.
I'm not sure about that. The elevator just changes the pitch, which in turn changes AoA and lift. The elevator is not responsible for the loop rotation IMO. Acctually, a model plane with Clarx y profile won't fly straight down, but will start to loop until level with the elevator in neutral. Negative elevator is required to maintain straight vertical flight (up or down).
Jernej
I think that you're over-complicating things, jernejk. It essentially just boils down to the fact that the elevators act like any other control surface; they deflect the airflow, and are deflected by it in response, which causes a torque about an axis. That torque affects in which direction the wings provide lift. You can get the same effect by cutting slots in the back of a paper aeroplane's wings and bending the tabs up, without regard to airfoil shape, C of G, or anything else.
Ok. That'll work, but as a caveat, 0 aoa is often defined so that an airfoil produces zero lift. Anyway, though...
Ok, but how is that useful? It doesn't affect what the plane is doing.
Right...
I think I agree with Danger that you are overcomplicating things. If you had a Mig-29, you could change your pitch 100 degrees without affecting the direction of flight, but as long as you don't depart from controlled flight, elevator changes pitch, which increases lift. If the lift is greater than the weight, the plane's forward direction starts to angle up, so unless the pilot eases off the elevator (or it is in the part of the envelope where the lift cancels the elevator input), the pitch will continue to increase and the plane will loop.
Well, whatever - that's just a matter of trim. It doesn't change anything about the discussion here.
I agree with Danger and Russ you are complicating matters it does a loop because there is a person on the ground iterfering with its flight path. Any plane will only fly straight & level with a certain trim at a certain speed. To keep it level at a higer speed more down trim needs to be applied as more airflow over the wings generate more lift. When the elevtor is pulled up, in a loop, the angle of attack is changed and the aircraft lifts its nose. With a glider this results in a drop in speed and airflow over the wing and to complete the loop more up elevator is required tocomplete the maneuver. After the apex of the loop gravity speeds the aircraft and progressively less elevator is required to comlete the loop.
  • · Replies 33 ·
  • · Replies 34 ·
10K
  • · Replies 30 ·
  • Poll Poll
  • · Replies 16 ·
11K
