Final Velocity of Electron Accelerated from Rest Through Potential Difference
The discussion revolves around the final velocity of an electron that is accelerated from rest through a potential difference. The subject area includes concepts from electromagnetism and relativistic physics.
  • Participants discuss the use of relativistic versus non-relativistic energy equations to determine the final velocity of the electron. Questions are raised about the appropriateness of the equations used given the high potential difference.
Participants are actively engaging with the problem, questioning assumptions about energy equations and clarifying the correct approach to take. Some guidance has been offered regarding the use of relativistic kinetic energy concepts.
There is mention of potential confusion regarding the application of relativistic effects due to the high potential difference, and the original poster expresses uncertainty about their calculations leading to unrealistic results.
Gyroscope
An electron is accelerated from rest through a potential difference of V volts. What is the final velocity?
I did:
[tex]qV=\frac{mc^2}{\sqrt{1-\frac{v_f^2}{c^2}}}[/tex]
And solve for v, but I get an unreal answer. What am I doing wrong?!
Why are you using relativistic energy?
Because there is an high potential difference. If I use non-relativistic energy it gives a speed higher than the speed of light. :rolleyes:
Could you post more of the question and your work?
If I'm not mistaken(Memory sometimes betray me) qV=(Gamma-1)mc^2
ziiad this is the relativistic kinetic energy, what I need is the relativistic change in kinetic energy.
No, you are right. What a stupid mistake of mine. :( Thanks, mate.
Don't worry, we all make mistakes, they key part was "...accelerated from rest..."
  • · Replies 16 ·
