Photons in the stationary wave?
  • Context: Graduate
  • Thread starter Thread starter bernhard.rothenstein
    Photons Wave
The discussion revolves around the behavior of photons in the context of stationary waves formed by two electromagnetic waves propagating in opposite directions. Participants explore the implications of this setup from both stationary and moving observer perspectives, touching on concepts from quantum field theory (QFT) and special relativity.
  • One participant asks for a narrative on photon behavior during the transition from propagating to stationary waves, considering the perspective of a moving observer.
  • Another participant explains that in QFT, photons are quanta of the electromagnetic potential field and can be represented as superpositions of traveling waves. They mention that the Doppler effect will alter the wave characteristics in a moving frame.
  • A participant reiterates the idea that a stationary wave can be expressed as a sum of two electromagnetic waves with equal but opposite wavenumbers, noting that the probability current is zero while the photon still travels at speed c.
  • Further elaboration includes the concept that the nodes of a stationary wave can act as a ruler, and the oscillations can serve as clocks, with relativistic effects like Lorentz contraction and time dilation affecting the perception of these nodes from a moving frame.
  • Another participant discusses the distinction between different types of observers and their measurement capabilities, questioning whether the proposed observer fits into a specific category of observer in relativity.
Participants express various viewpoints on the behavior of photons and the implications of stationary waves, but no consensus is reached. There are competing interpretations regarding the effects of relativistic phenomena on measurements and the nature of observers.
Some limitations include the dependence on definitions of observers in relativity, the unresolved nature of how lengths transform under different effects, and the complexity of the mathematical relationships involved in the discussion.
Consider that an observer composes two electromagnetic waves of the same frequency propagating in opposite directions in order to obtain a stationary wave. Please tell me a short story about the behaviour of the photons in the transition from propagating waves to a stationary one.
What does detect an observer moving relative to me and watching the experiment I just perform. Thanks.
In QFT, photons are quanta of the EM potential field, just as electrons are quanta of the electron field. In either case, the quanta of a standing wave can be written in terms of quanta of traveling waves in opposite directions.
The photon or electron would be such a superposition. Going to a moving frame, the Doppler frequency shift would be different for each component, so the character of the wave will change. It is a homework exercise to calculate the change. The answer for photons, will be the same as for classical EM plane waves.
stationary wave
Thank you. That is the way in which I am looking for help on the Forum. We did the homework exercise in order to show the conservation of the number of counted photons.
A simple sum of two EM waves with equal but opposite wavenumbers k and -k (kc=frequency) can represent a photon that is moving in either the + or -x direction. The photon is moving at c but its probability current is zero. From a moving frame the two opposite k's will not be the same because of their doppler shifts, but the photon will still be moving at c in either the + or -x' direction. The probability current is flowing at v. It is clear that there is still only one photon. As more photons are added to the state the number is likewise conserved between the rest and moving frames.
The nodes of the standing wave form a stationary ruler and the oscillations of the amplitude between nodes provide a set of stationary clocks. When viewed from a moving frame, the doppler shifts of the two component waves make the moving nodes appear closer together by the Lorentz contraction and the oscillations become slower by the relativistic time dilation. The observer at rest can construct a moving node ruler and moving oscillation clocks by using two oppositely moving waves of different frequency. Stationary and moving space-time grids can be built in this way with light waves.
special relativity in the stationary wave
Thanks for the interesting idea you offer.
So far as I know relativists make a net distinction between observers equipped with rods and synchronized clocks located at differfent points in space confronted with effects like time dilation and length contraction, and observers located at a given point in space collecting information about events taking place at different points in space form the light that arrives at the point where they are located confronted with effects like Doppler or aberration.
Do you consider that the observer you propose is an uptodated first kind of observer?
I have to think if the lengths involved transform by contraction or by Doppler effect?
Kind regards:smile:
The two observers in my example, moving and at rest, each collect information from measurements at various locations in their respective frames. The measurements at each location are made by observers or recording/transmitting devices. Since the central observer who collects the information from distant points can compile it over a period of time, his results are not affected by times-of-flight from the distant points. He is probably not like the second type of observer you describe above. Instead, the many observers or devices at distributed locations are like your first type of observer.
  • · Replies 25 ·
  • · Replies 26 ·
  • · Replies 34 ·
  • · Replies 32 ·
  • · Replies 33 ·
  • · Replies 20 ·
