| Thread Closed |
3-4-5 triangle |
Share Thread | Thread Tools |
| Mar12-07, 10:15 AM | #1 |
3-4-5 triangle
Hey, I have quick question. I tried looking on google, but couldn't quite reassure myself. Does a 3-4-5 triangle have to be a 30-45-90 triangle? Can the angles be any angle?(this is what I think....but not confident). I have a triangle(this is actually a physics problem)....but the triangle has a leg which is 3' and a leg that is 4'.....so the hyp must be 5'....but i need to know the angles. 2. Relevant equations 3. The attempt at a solution |
| Mar12-07, 10:21 AM | #2 |
No. |
| Mar12-07, 10:29 AM | #3 |
There exists no triangle with 30-45-90 angles. The sum of the angles must be 180.
It should be noted that the majority of sine, cosine and tangent arguments only work for right angled triangles. It's not necessarily true that a RIGHT triangle with 3 inch and a 4 inch lengths will have another side of length 5. How do you know that 4 isn't the hypoteneuse? |
| Mar12-07, 10:32 AM | #4 |
Recognitions:
3-4-5 triangleYou can find the angles of any shape of triangle using the cosine rule, if you know all three sides. For a 3-4-5 triangle, you know one angle is right angle, so you can save time and use the definitions of sine and cosine instead of using the full cosine rule. |
| Mar12-07, 10:32 AM | #5 |
I have a picture......I guess I'm having a brain fart.....
I know there is a 90 deg angle(where the 3 and 4 sides meet,angle opposite from the hyp).....so then, can't i use the law of sines to find the angles? I know the def's of trig functions........what does that help.......opp/adj......opp/hyp......adj/hyp.... |
| Mar12-07, 10:35 AM | #6 |
| Mar12-07, 10:35 AM | #7 |
ok......so can't I just do this.....
sin90/5 = sinx/3 which I think gives me a 36.87 deg angle. This is what I came up with in the begining....just didn't seem right. |
| Mar12-07, 10:36 AM | #8 |
tan = opp/adj.......or I think its also sin/cos(or something like that.....y/x?).....definately know its tan.
| Mar12-07, 10:36 AM | #9 |
Recognitions:
| Mar12-07, 10:37 AM | #10 |
ok.....well I think I've got it then......thanks all! A nice brush up on my trig skills....ha
| Thread Closed |
| Thread Tools | |
Similar Threads for: 3-4-5 triangle
| About a triangle.... | Introductory Physics Homework | 6 | ||
| triangle | Brain Teasers | 13 | ||
| help with triangle | Introductory Physics Homework | 1 | ||
| triangle help | General Math | 1 | ||
| EM Triangle | General Physics | 1 | ||
