Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
Go Back   Physics Forums > Science Education > Homework & Coursework Questions > Calculus & Beyond
Notices
Reply
image angle trisection Share It Thread Tools Search this Thread image
Old Mar13-07, 01:09 PM       Last edited by happyg1; Mar13-07 at 01:11 PM.. Reason: tex errors            #1
happyg1
happyg1's Avatar
happyg1 is Offline:
angle trisection
Prove that it is possible to trisect 72 degrees.
2. Relevant equations
LaTeX Code: cos(3\\theta)=4cos^3(\\theta)-3cos(\\theta)
3. The attempt at a solution
well,72/3=24, So I need to see if cos24 is constructible, Which means that it is a root of a polynomial with a degree that is a power of 2.(?)I think.
I did this:LaTeX Code: cos(72)=\\frac{\\sqrt5-1}{4}
and LaTeX Code: Let \\theta=24
so then letting LaTeX Code: cos\\theta=x in the equation above,
I get:
LaTeX Code: (\\sqrt5)=(16x^3+12x+1)
Now I get a little confused about what I'm trying to do.
Here's what I need help with:
Firstly, am I on the right track here?
Secondly, Is the "degree of a power of 2" (above) correct?
What is it that I need to do with this polynomial from here?
I've confused myself.
CC
Old Mar13-07, 03:23 PM                  #2
happyg1
happyg1's Avatar
happyg1 is Offline:
Any advice?
Old Mar14-07, 07:47 AM                  #3
HallsofIvy
PF Mentor
HallsofIvy is Offline:
Yes, that is (almost) correct. A number is "constructible" if and only if it is "algebraic of order a power of 2" which means it is a zero of a polynomial with integer coefficients of degree a power of two. The "with integer coefficients" is why I said "almost".
I get:
Not quite. In the first place, the right hand side should be
LaTeX Code: 16x^3- 12x+ 1
In the second, you can't have LaTeX Code: \\sqrt{5} - that's not an integer. What you want to say is that if x= cos(24) , then x satisfies
LaTeX Code: 5= (16x^3- 12x+ 1)^2
which is a 6th degree equation. Now, you need to show that it can be reduced to either a 4th or 2nd degree equation- that it has either rational numbers or square roots as solutions. I'm not at all sure how you are going to do that!
CC
Old Mar14-07, 08:36 AM                  #4
happyg1
happyg1's Avatar
happyg1 is Offline:
Hey,
Thanks for looking at this. Now I'm not QUITE so cunfused. I'll fix my algebra and see where I can get.
CC
Old Mar14-07, 09:22 AM                  #5
happyg1
happyg1's Avatar
happyg1 is Offline:
OK
Please let me know of this is correct. I fixed my sign error(der) and squared the thing to get rid of the square root:
LaTeX Code: 5=256x^6-384x^4+32x^3+144x^2-24x+1
LaTeX Code: 256x^6-384x^4+32x^3+144x^2-24x-4=0
Which factors like this:
LaTeX Code: 4(4x^2+2x-1)(16x^4-8x^3-16x^2+8x+1)
The quadratic factor has square roots as the zeros and the 4th degree has cos24 as one of the roots. So x=cos24 satisfies that 4th degree polynomial factor with integer coefficients. 4 is a degree of a power of 2, so cos24 is constructible?
Am I any closer?
CC
Old Mar14-07, 03:10 PM       Last edited by HallsofIvy; Dec9-07 at 03:40 AM..            #6
HallsofIvy
PF Mentor
Wow, I am impressed! When I wrote my previous reply, I was tempted to add "Good luck with trying to factor that"!
Yes, if cos(24) satisfies the original equation (and you say it does) then it must satisfy one or the other of the factors equal to 0. You should be able to solve 4x2+ 2x-1= 0 to determine if it is that one but it really doesn't matter- cos(24) is either algebraic of order 4 or algebraic of order 2. In either case it is constructible.
Old Mar14-07, 05:10 PM                  #7
Hurkyl
PF Mentor
Hurkyl's Avatar
Hurkyl is Online:
Some ("most", actually) irreducible 4-th degree polynomials have roots that are not constructible.
Old Mar14-07, 08:07 PM                  #8
HallsofIvy
PF Mentor
It ocurred to me after I responded that you do need to show that the 4th degree polynomial is irreducible.
If the second degree polynomial happened to be reducible then it would follow that the root is either algebraic of order 1 or order 2, both of which are algebraic or order a power of 2.
If the 4th degree factor were separable, then it would either be factored into two quadratic factors (in which case x would be algebraic of order 1 or 2, both powers of 2) or factored into a cubic and a first degree factor. In that last case, where there is a first degree factor, then
LaTeX Code: (16x^4-8x^3-16x^2+8x+1)
has a rational root. By the "rational root theorem", any rational roots must have denominator that evenly divides 16: i.e. LaTeX Code: \\pm 1 , LaTeX Code: \\pm 2 , LaTeX Code: \\pm 4 , LaTeX Code: \\pm 8 or [/itex]\pm 16[/itex] and denominator that evenly divides 1: i.e. LaTeX Code: \\pm 1 . In other words, the only possible rational roots are LaTeX Code: \\pm 1 , LaTeX Code: \\pm \\frac{1}{2} , LaTeX Code: \\pm \\frac{1}{4} , LaTeX Code: \\pm\\frac{1}{8|} , or LaTeX Code: \\pm\\frac{1}{16} .
Do any of those satisfy the equation?
Old Mar15-07, 01:14 PM                  #9
happyg1
happyg1's Avatar
happyg1 is Offline:
I'm a little confused about this. The 4th degree polynomial that I got has no rational roots, so that means that cos24 isn't rational, but it's constructible? Yes?
And also, from the quadratic, can I conclude that cos72 is constructible? That one hasLaTeX Code: \\frac{\\sqrt5-1}{4}=cos72 as a root.
And then since cos72 is constructible, so is a regular pentagon?
I thought that this might be true because 360/5=72.Is this the angle of interest? Or is there another method to show the pentagon is constructible?
I have attempted to prove that the hexagon is constructible and I keep getting a cubic. i know I'm wrong. That's another post tho.
BTW, on that factorization, I had gotten stuck because I had the wrong sign the first time. I scrawled about 3 pages trying to figure it out and then I busted out the TI89. Don't be too impressed.
CC
Old Dec8-07, 05:09 PM                  #10
dubi
dubi is Offline:
Some info on trisection
The ever-dubious wikipedia has some info on trisection -- full disclaimer, I wrote it -- at
< http://en.wikipedia.org/wiki/Angle_trisection >. The book by Ian Stewart I own, and is
available in updated editions.
Another reference that trisects 72 degrees (big .pdf file, search for "72") is
< http://www.math.uncc.edu/~droyster/c.../Chapter03.pdf >.
The construction is a little messy, but looks valid to me.
dino, not "dubi," -- too fast on the keyboard.
Old Jun12-10, 12:58 AM                  #11
pogovio
pogovio is Offline:
Re: angle trisection
Sometimes too much knowledge can distract us in the wrong direction. This problem actually doesn't require anything about the forms of equations for cos 24. Its a much simpler problem.
If you have a 72-degree angle, then construct a 60-degree angle, and subtract from 72, leaving a 12-degree angle. Double it, and you have the 24-degree angle, which is 1/3 of 72.
image image
Reply
Thread Tools
Similar Threads for: angle trisection
Thread Thread Starter Forum Replies Last Post
first angle,third angle projection chandran Engineering Systems & Design 28 Mar28-10 12:01 PM
A new angle on the Right Angle Lever Paradox. yuiop Special & General Relativity 27 Aug20-08 11:32 AM
How does the angle at which a ray of light strikes a prism compare with the angle at zachcumer Introductory Physics 9 Apr1-08 07:51 PM
Trisection of hyperpolyhedra Loren Booda General Math 0 Feb16-07 10:30 PM
Launch Angle Q's with no Angle Counsellnfc Introductory Physics 1 Sep4-06 07:10 PM
Powered by vBulletin Copyright ©2000 - 2010, Jelsoft Enterprises Ltd. © 2010 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
