Proving <x, T_a> is Nonzero for Countable a in Hilbert Space H
The discussion revolves around proving that the inner product is non-zero for at most countably many indices a in the context of a Hilbert space H, where {T_a} is an orthonormal system and x is an arbitrary vector in H.
  • Participants explore the implications of summing an uncountable number of non-zero terms and question the convergence of the series formed by the inner products. They discuss the relevance of Bessel's inequality and the conditions under which the absolute values of the inner products can be greater than a fixed positive number e.
There is an active exploration of the relationship between the inner products and the properties of convergent series. Some participants suggest that if the inner product is non-zero for uncountably many a, it leads to contradictions regarding the convergence of sums. Others are questioning the clarity of certain statements and the need for a more formal proof structure.
Participants are navigating the constraints of the problem, particularly regarding the definitions of linear combinations in Hilbert spaces and the implications of summing infinite terms. There is an ongoing discussion about the nature of convergence and the conditions under which the inner products can be considered non-zero.
Raven2816
{T_a} is an orthonormal system (not necessarily countable) in a Hilbert space H. x is an arbitrary vector in H.
i must show that the inner product <x, T_a> is different fron 0 for at most countably many a.
i'm not even quite sure where to begin. i know that the inner product is the sum(B_aT_a) in a hilbert space, but I'm sure what other information i have to work with.
thanks
Can you sum an uncountable number of non-zero terms?
And what can you say about the sum of |<x,T_a>|^2?
could i use the Bessel inequality?
or if i fix an e>0...for how many a can it be true that the absolute value of <x, T_a> is greater than e?
Take the hints you were given. It is impossible for this vector to have a length because you cannot sum an uncountable number of strictly positive terms. Prove it.
This is on the right track. Now answer your own question. How many? Be careful though - how do you know sum |<x,T_a>| converges? Hint: in general, it doesn't.
that's a great question. how DO i sum the absolute value of inner products when there are infinite terms? it won't converge. so for a fixed e>0, there are countably many a for which <x, T_a> is greater than e...but why
What does Bessel's inequality tell you? As for how many terms in a convergent infinite series can be greater than some positive number e, can the number even be infinite?
You learned in calculus how to sum an infinite number of terms! But those were all countable sums. Precisely what is meant by "linear combination" here? If there were an uncountable number of terms with non-zero inner product that would give a linear combination of the basis vectors with an uncountable number of non-zero terms. Is that possible the way "linear combination" is defined in a Hilbert space?
i know there are countably many nonzero terms...because eventually i will have terms that are no longer linearly independent.
i know there are countably many a such that for e>0 the absolute value of <x, T_a> is greater than e. i know that i can't sum an uncountable number of strictly positive terms because it doesn't converge. i just don't understand everything in the middle that should tie this together.
I don't follow you.
You claim that you can show that if <x,T_a> is non-zero for uncountably many a (which implies <x,x> is infinite), then it is a contradiction. But that was all you were asked to show.
i know that <x, T_a> is non-zero for countably many a. I'm just struggling to show that this is in fact true.
Um. But you just said that if it were false, then you can show a contradiction. Therefore it is true. You can't sum an uncountable number of positive terms. And you know
<x,x>^2 => sum <x,T_a>^2
and the RHS doesn't exist if there are not countably many non-zero terms.
so i can say that since that equality is true, and i can't sum uncountable positive terms, that obviously there are countably many a where the inner product is nonzero? is that a complete answer? it makes intuitive sense, but is it legit?
Of course it is legit. Why wouldn't it be? You've shown not(B) implies not(A), thus A implies B.
WHAT equality is true? I haven't seen any equalities playing a big role here. And the reason why you can't have an uncountable number of positive terms in a convergent series isn't because it's 'obvious'. I'm not even sure any of this is 'intuitive'. I think you are going to have to state more of this in the form of a 'proof'.
I think he meant inequality.
I hope so.
  • · Replies 43 ·
  • · Replies 0 ·
  • · Replies 61 ·
  • · Replies 16 ·
