Thread Closed
easy definition of enthalpy
Share Thread Thread Tools
Mar17-07, 04:46 PM   #1
I am having a bit of trouble grasping the idea and definition of enthalpy. I was wondering if someone could help.
Am I correct in saying that a change in enthalpy only occurs if there is no temperature change? i.e. during a phase change/chemical change at constant temp?
Thus since there is no change in temperature, there is no change in kinetic energy. The change in enthalpy is equivalent to a change in potential energy for the molecules involved as they separate/bond.
For some reason I was confused because I thought that enthalpy was "the total kinetic and potential energy of the system" as defined in my textbook, but if temperature cannot change, by definition kinetic energy cannot change right?
Can someone let me know whether or not my assumptions about temperature change are correct?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> King Richard III found in 'untidy lozenge-shaped grave'
>> Google Drive sports new view and scan enhancements
>> Researcher admits mistakes in stem cell study
Mar17-07, 05:09 PM   #2
Let me expand my explanation a little. When calculating the energy change of a system, we use the forumla q=mc[tex]\Delta[/tex]t if there are no phase changes, which makes perfect sense. We only use the formula [tex]\Delta[/tex]H=nH where [tex]\Delta[/tex](H is the change in enthalpy and H is the molar enthalpy value for whatever phase change, and n is the amount of substance in molar units) during a phase change. It seems that a change in enthalpy is a change in potential energy, since the temp does not change in the calculation, but then my textbook says its the total value of the potential and kinetic energy of the molecules in the substance, so I am confused.
Mar19-07, 11:14 AM   #3
Other Sciences 2012
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
Enthalpy is heat. If heat can change temperature, then a temperature change is observed. If heat is used to change the phase of a material, temperature will not change.
Thread Closed
Thread Tools
Similar Threads for: easy definition of enthalpy
Thread Forum Replies
Enthalpy of Formation vs. Bond Enthalpy Biology, Chemistry & Other Homework 7
enthalpy so commonly described only in constant pressure situations? Classical Physics 1
Enthalpy Biology, Chemistry & Other Homework 5
Enthalpy of Dissolution vs. Enthalpy of Solution Biology, Chemistry & Other Homework 4
Enthalpy AP Chemistry Chemistry 5
