New Reply
Jackson Electrodynamics problem 6.5b
Share Thread
Mar19-07, 08:20 AM   #1
Unhappy
A localized electric charge distribution produces an electrostatic field,
[tex]
{\bf E}=-\nabla \phi
[/tex]
Into this field is placed a small localized time-independent current density J(x) which generates a magnetic field H.
a) show that the momentum of these electromagnetic fields, (6.117), can be transformed to
[tex]
{\bf P_{field}}=\frac{1}{c^2}\int \phi {\bf J} d^3x
[/tex]
b) Assuming that the current distribution is localized to a region small compared to the scale of variation of the electric field, expand the electrostatic potential in a Taylor series and show that
[tex]
{\bf P_{field}}=\frac{1}{c^2}{\bf E(0)\times m}
[/tex]
where E(0) is the electric field at the current distribution and m is the magnetic moment (5.54), caused by the current.
2. Relevant equations
(6.117):
[tex]
{\bf P_{field}}=\mu_0 \epsilon_0 \int {\bf E \times H} d^3x
[/tex]
(5.54):
[tex]
{\bf m}=\frac{1}{2} \int {\bf x' \times J(x')} d^3x'
[/tex]
3. The attempt at a solution
Part a) was straight forward: subsituting E=- grad phi and integrating by parts gives the answer plus a surface integral that goes to 0 if phi*H goes to 0 faster than 1/r^2.
Part b): This is where I get stuck. I tried to put
[tex]
\phi=\phi(0)+\nabla \phi(0)\cdot{\bf x}
[/tex]
which replaced in the integral for P_field from a) gives
[tex]
{\bf P_{field}}=-\frac{1}{c^2} \int {\bf (E(0)\cdot x) J)} d^3x
[/tex]
if I choose the potential to zero at the origin. Further, using
[tex]
{\bf a\times (b\times c)=(a\cdot c) b-(a\cdot b)c}
[/tex]
on the integrand I get
[tex]
{\bf P_{field}}=\frac{1}{c^2} (\int {\bf E(0)\times (x\times J) }d^3x-\int{\bf (E(0)\cdot J)x}\,d^3x)
[/tex]
The first integral is as far I can see
[tex]
\frac{2}{c^2} {\bf E(0)\times m}
[/tex]
that is, twice the answer. The second integral gets me stuck. I guess I should show that it is equal to minus half of the answer (if I did everything correctly so far), but I don't see how to do this.
I would appreciate if anyone could give me a hint on how to continue or if I'm on the right track at all. Thanks in advance!
PhysOrg.com science news on PhysOrg.com
>> City-life changes blackbird personalities, study shows
>> Origins of 'The Hoff' crab revealed (w/ Video)
>> Older males make better fathers: Mature male beetles work harder, care less about female infidelity
Mar19-07, 09:00 AM   #2
Recognitions:
Homework Helper Homework Help
Somewhere else in Jackson (and other texts) it is shown the second integral
equals EXm. It's in Sec. 5.6 of teh 2nd Edition, if you can follow it.
Mar19-07, 09:52 AM   #3
If you believe that the second integral is indeed equal to Exm, then why not simply write them both out in components to prove it? Granted it's not really a proper derivation, but you were only asked to show that the formula is true.
Mar19-07, 10:46 AM   #4
Thanks for your replies, it was very helpful! Using section 5.6 of Jackson as you said I saw that I could show directly that the first integral
[tex]
[/tex]
is equal to the sought answer without using the abc vector rule. Looking below eq. 5.52 (in the 3rd edition) and substituting x by E(0) the whole derivation is there.
Apr27-11, 12:20 AM   #5
How about the part C
New Reply
Similar discussions for: Jackson Electrodynamics problem 6.5b
Thread Forum Replies
Jackson Electrodynamics problem 9.8a Advanced Physics Homework 2
Jackson Electrodynamics Problem 2.3 Advanced Physics Homework 4
Jackson Electrodynamics Academic Guidance 10
? is to QM as Jackson is to electrodynamics. General Physics 3
Need help with EM/Jackson problem Classical Physics 2
