Solving Gauss' Law: E Field & Volume Charge Density
This discussion focuses on solving Gauss' Law problems related to electric fields and volume charge density. For the first problem, the electric field (E) between two charged plates is calculated using the formula E = σ/ε₀, resulting in a surface charge density (σ) of 4.868 x 10^-10 C/m². The second problem involves deriving the electric field (E) within a non-conducting sphere with uniform volume charge density (ρ), leading to the conclusion that E = ρr/3ε₀. The use of Gaussian surfaces is emphasized for simplifying calculations.
  • Understanding of Gauss's Law
  • Familiarity with electric field concepts
  • Knowledge of surface charge density (σ) and volume charge density (ρ)
  • Basic calculus for integrating over spherical surfaces
  • Study the derivation of electric fields using Gauss's Law in various geometries
  • Learn about the implications of surface charge density in electrostatics
  • Explore the relationship between electric field strength and charge distribution
  • Investigate the applications of electric fields in capacitors and other devices
Students and educators in physics, electrical engineers, and anyone studying electrostatics and electric field calculations.
suspenc3
1.)Two large metal plates of area [tex]1.0m^2[/tex] face each other. They are 5 cm apart and have equal but opposite charges on their inner surfaces. If the magnitude E of the electric field between the plates is 55N/C, what is the magnitude of the charge on each plate?Neglect edge effects
2.)A non conducting sphere has a uniform volume charge density [tex]\rho[/tex]. Let r be the vector from the center of the sphere to a general point P within the sphere. Show that the electric field at P is given by [tex]E=\rho r/3\epsilon_0[/tex]
[tex]E=\sigma/\epsilon_0[/tex]
1.)[tex]E=\sigma/\epsilon_0[/tex]
[tex]E\epsilon_0=\sigma=(55N/c)(8.85x10^{-12}F/m)=4.868x10^{-10}C/m^2[/tex]
[tex]E=\sigma/2\epsilon_0=\frac{4.868x10^{-10}C/m^2}{2(8.85x10^{-12}F/m} = 27.5N/C[/tex]
Im guessing that I did this wrong, it seemed too easy.
2.)I don't know how to start this one.
For the second problem, just use Gauss's law.
[tex] \int_S \vec{E} \cdot \, \vec{dA} = \frac{q}{\epsilon_0}[/tex]
The important thing is to be careful in selecting your surfaces. Here's a suggestion -- use a Gaussian surface that is a spherical shell concentric with the sphere itself.
So the left side simplifies essentially to EA, where A is just [itex]4\pi r^2[/itex], where A is the surface area of our Gaussian surface (r < R).
Now, how do you find q? That is, how do you find the charge enclosed by our Gaussian surface? (I'll leave this part to you.)
  • · Replies 26 ·
