Emptying a Bowl: Calculating Work
  • Thread starter Thread starter teken894
    Work
The discussion focuses on calculating the work done to empty a hemispherical bowl with a radius of 8 inches, filled with punch weighing 0.04 pounds per cubic inch, to within 2 inches of the top. The correct approach involves using the formula for work, defined as the product of force (weight) and displacement. The weight is calculated using the equation weight = (0.04)(π * r²)dx, leading to the total work being represented by the integral from 2 to 8 of (0.04π)(x)(64 - x²)dx. This method accurately accounts for the displacement and weight of the liquid being pumped over the rim.
  • Understanding of calculus, specifically integration techniques.
  • Familiarity with the concept of work in physics.
  • Knowledge of the geometry of hemispherical shapes.
  • Basic understanding of fluid mechanics and weight density.
  • Study integration techniques for calculating work in physics problems.
  • Learn about the properties of hemispherical volumes and their applications.
  • Explore fluid mechanics principles related to weight density and buoyancy.
  • Review examples of similar problems involving work and displacement in calculus.
Students studying calculus and physics, particularly those focusing on applications of integration in real-world scenarios involving work and fluid dynamics.
teken894
A hemispherical bowl with radius 8-inches is filled with punch (weighing .04 pound/in^3) to within 2-inches of the top. How much work is done emptying the bowl if the contents are pumped just high enough to get over the rim?
Work = Force(weight)* displacement.
i said displacement was "x"
and for the weight:
r = sqrt(64- x^2)
weight = (.04) (pi * r^2)dx
and so, work to lift weight at a given "x"
is weight*displacement
so i get total work is
integration from 2 to 8 of
(.04pi)(x)(64 - x^2)dx
Is this the right way to approach this problem?
Is it being pumped from underneath so that there is free space between the liquid and the bowl?
Yes, that is exactly right!
14K
