Solve 37 x 0.785 w/ Logarithms (Base 10, e & 5)
  • Thread starter Thread starter chemical
    Base Index
This discussion focuses on solving the multiplication of 37 and 0.785 using logarithms in various bases: 10, e, and 5. The method involves applying the logarithmic property that states log(a * b) = log(a) + log(b). For base 10, the calculations yield log(37) = 1.5682 and log(0.785) = -0.1061, resulting in log(37 * 0.785) = 1.4631, leading to an anti-logarithm of 29.04. The same approach is applied for natural logarithms and base 5, confirming the product remains consistent across calculations.
  • Understanding of logarithmic properties, specifically log(a * b) = log(a) + log(b).
  • Familiarity with anti-logarithms and their calculation.
  • Basic knowledge of logarithmic tables and calculator usage.
  • Concept of logarithms in different bases (base 10, e, and base 5).
  • Learn how to calculate logarithms and anti-logarithms using scientific calculators.
  • Explore the historical significance of logarithms in mathematical computations.
  • Study the application of logarithms in solving exponential equations.
  • Investigate the differences between common logarithms (base 10) and natural logarithms (base e).
Students learning logarithmic calculations, educators seeking alternative teaching methods, and anyone interested in the historical context and practical applications of logarithms in mathematics.
chemical
im sick of logs
use base and index steps to show the answer to 37 x 0.785 using logarithms with a base of 10, e and 5.
i just want to know how to start this problem.
thanks in advance
I'm really not sure what "base" and "index" steps are.
And I must admit that I'm surprised to see anyone using logarithms to actually do multiplications in this era! It's an interesting historical fact, but I consider the use of logarithms as the "inverse" of exponentials to be a much more important use.
I suspect what you are looking at is:
The log(37 x 0.785)= log(37)+ log(0.785) in any base. If you were doing this in base 10 and looking the values up in a table (why would anyone do that anymore), you would find that the table only contains logarithms of numbers from 1 to 10 and so does not contain either
37 or 0.785. What you would do is write 37 as 3.7* 10 and then look up the logarithm of 3.7 (it's 0.5682 to 4 decimal place- I used a calculator, not a table!) and note that the log of 10 is 1 simply because 10= 101 so that the log of 37 is 1.5682. Now write 0.785 as 7.85*10-1. Look up the log of 7.85 (it's 0.8949-guess how I got that!) and of course, the log of 10-1 is -1. In the "olden days" we would simply write that as
0.8949-1. Now, we know that log(37*0.785)= 1.5682+ 0.8949- 1= 1.4631 (yes, I used a calculator to do that sum!). Now "looking up" the anti-logarithm of that (once upon a time you just used your table of logarithms in reverse), the anti-log of 0.4631 is 2.904. Since the anitlogarithm of 1 is 10, the result is 2.904*10= 29.04 (remarkably enough, that's what my calculator gives as the product of 37 and 0.785!).
As far as base e and base 5 are concerned, I used to have a book of math tables that had natural logarithms but I don't recall ever using them! I doubt that anyone has ever made a table of logarithms base 5. Yes, you could use your calculator to determine the logarithms but why would you rather than just doing the multiplication on a calculator.
Well, if you insist, ln(37)= 3.6109 (that makes sense- e is about 2.7 and 33= 27) and ln(0.785)= -.2421 (negative because 0.785 is less than one. Remember that "-1" on the common logarithm?).
The sum of those is 3.6109- .2421= 3.3688 and the "anti-logarithm" (e to that power) is 29.04 again. I still not sure what the "base" and "index" steps are unless the "base" part is taking the logarithm and the "index" part is the anti-logarithm.
As for base 5, my calculator (and I suspect yours) does not have a "logarithm base 5" key but I'm sure you know that the log base 5 of 37 is log(37)/log(5) where it does not matter which log you use:
log(37)/log(5)= 2.2436 (again, that makes sense. 52= 25 and 37 is a bit larger than that) and log, base 5, of 0.785 is
log(0.785)/log(5)= -0.1504. That tells us that log, base 5, of 37*0.785 is 2.2436- 0.1504= 2.0931. And, of course, 37*0.785= 52.0931= 29.04 again.
I can't tell you how silly I feel using a calculator to determine the logarithms and do the addition when it would be much easier to use the calculator to do the multiplication itself!
oh my god thanks a lot Ivy. the help was so much appreciated!
what can i say our teacher is a bit backwards in teaching methods. we basically have to figure out log numbers without calculators and slide rules!
once again thanks
