Solve Fourier Transform Problem: f(t)=e^(-t^2/a^2)
The Fourier transform of the function f(t)=e^(-t^2/a^2) is calculated using the definition of the Fourier transform and properties of exponential functions. The integral F(w)=integral from -infinity to infinity of f(t)e^(i*w*t)dt simplifies through completing the square and applying the Gaussian integral formula. The final result is F(w)=sqrt(pi)*a*e^(-a^2*w^2/4), which matches the answer provided in the textbook. This method effectively demonstrates the application of Gaussian integrals in Fourier analysis.
  • Understanding of Fourier transforms
  • Familiarity with Gaussian integrals
  • Knowledge of complex numbers and exponential functions
  • Ability to complete the square in algebraic expressions
  • Study the properties of Fourier transforms in signal processing
  • Learn advanced techniques for solving Gaussian integrals
  • Explore applications of Fourier transforms in physics and engineering
  • Investigate the implications of complex exponentials in Fourier analysis
Students in mathematics, physics, and engineering, particularly those studying signal processing and Fourier analysis, will benefit from this discussion.
RyanA1084
Hi all, I had this problem for homework and it stumped me. It's too late to get points for it, but I'd like to know for future reference.
Find the Fourier transform F(w)=integral from -infinity to infinity of f(t)e^(i*w*t)dt
f(t)=e^(-t^2/a^2)
i=sqrt(-1) w=omega=constant a=constant
This looks sort of like a gaussian integral:
integral of e^(-a*x^2)dx=sqrt(pi/a)
but I couldn't see how to do it...
The answer given by the book is sqrt(pi)ae^(-a^2*w^2/4)
Anyone know how to do this??
I think the thing you want to do here is complete the square in the arguments of the exponential. In this expression:
-t^2/a^2 + iwt = -(t-b)^2 +c.
where you can find b and c. When you've done that you can change variables and you will have and expression for the Gaussian that you are familiar with.
To solve this problem, you can use the definition of the Fourier transform, which is F(w)=integral from -infinity to infinity of f(t)e^(i*w*t)dt. In this case, f(t)=e^(-t^2/a^2), so we can rewrite the integral as F(w)=integral from -infinity to infinity of e^(-t^2/a^2)e^(i*w*t)dt.
Next, we can use the property of exponential functions that e^(a+b)=e^a*e^b. In this case, a=-t^2/a^2 and b=i*w*t. So we can rewrite the integral as F(w)=integral from -infinity to infinity of e^(-t^2/a^2+i*w*t)dt.
Now, we can use the Gaussian integral formula mentioned in the post, which is integral of e^(-a*x^2)dx=sqrt(pi/a). In our case, a=-1/a^2, so we can rewrite the integral as F(w)=integral from -infinity to infinity of sqrt(pi/a^2)e^(-(-1/a^2)t^2+i*w*t)dt.
Next, we can factor out the constant sqrt(pi/a^2) and use the definition of the Fourier transform again. This will give us F(w)=sqrt(pi/a^2)integral from -infinity to infinity of e^(-(1/a^2)t^2+i*w*t)dt.
Now, we can use the substitution u=t/a, which will give us du=1/a dt. We can also rewrite the exponential term as e^(-(1/a^2)t^2+i*w*t)=e^(-(u^2-2iu*w))=e^(-(u-i*w)^2). This will give us F(w)=sqrt(pi/a^2)integral from -infinity to infinity of e^(-(u-i*w)^2)du.
Using the Gaussian integral formula again, we can rewrite the integral as F(w)=sqrt(pi/a^2)*sqrt(pi)*a*e^(-a^2*w^2/4). Simplifying this, we get F(w)=sqrt(pi)*a*e^(-a^2*w^2/4), which is the same answer given by the book.
In summary, to solve this Fourier transform problem, we used the definition of the Fourier transform, the property of exponential functions,
  • · Replies 16 ·
