Calculating Length of Parametric Curves
  • Thread starter Thread starter sonya
    Curves Length
The discussion revolves around calculating the length of a parametrized curve defined by specific equations for x(t) and y(t) over the interval from t = 0 to t = 1. Participants are exploring the appropriate formula and method for determining this length.
  • Participants discuss the formula for arc length, with some clarifying the derivation from the Pythagorean theorem. Questions arise regarding notation and the correct interpretation of the integral. There is also mention of potential misunderstandings in the integration process.
The conversation has seen participants offering guidance on deriving the length formula and checking the calculations involved. Some participants express uncertainty about their understanding of the integral and seek further clarification, while others indicate they have resolved their issues with integration.
There are mentions of notation that may cause confusion, particularly regarding the integral's variable and the area element. Additionally, some participants reflect on previous experiences with similar problems, which may influence their current understanding.
sonya
Find the length of the parametrized curve given by
x(t)=0t3+9t2+36t
y(t)=-1t3-6t2+15t
for t between 0 and 1.
ok...thats the question. I have tried using the formula L = integral of (dx/dt)2 + (dy/dt)2 all square rooted but I am not gettin the rite answer...i have a bunch of these questions haven't been able to get ne of them...if sum1 cud jst walk me thru this 1 it wud b a lot of help...thx
I've never seen a length formula like that.
I don't know what you may be missing, so let's start from the beginning.
[tex](dL)^2 = (dx)^2 + (dy)^2[/tex]
Now divide through by [tex](dt)^2[/tex]
[tex](\frac{dL}{dt})^2 = (\frac{dx}{dt})^2 + (\frac{dy}{dt})^2[/tex]
Take the positive square root of both sides:
[tex]dL/dt = \sqrt{(\frac{dx}{dt})^2 + (\frac{dy}{dt})^2}[/tex]
Here I assume you can now see how to get the correct length formula from that equation.
Compute dx/dt and dy/dt, square both quantities and substitute the results in the correct length formula.
Show what you get after these steps. I will be able to check my email tonight and Sunday after pacific coast time 2PM.
That's actually exactly the formula sonya said--well, almost. The "all square rooted" part kind of implied that the integral was square rooted, but it's pretty clearly what's inside the integral.
I just thought I'd mention that outandbeyond2004 began with the Pythagorean Theorem and went from there. It's all triangles!
cookiemonster
Cookiemonster, do some people write
[tex]\int f(x)[/tex]
instead of
[tex]\int f(x) dx[/tex]
If so, that makes me feel uncomfortable. The area element (area under the f(x) curve) is not evident in the first kind of notation above. Well, come to think of it maybe Sonya did mean dt in there, tho not explictly.
My PDEs professor is notorious for
You can imagine the headache, I'm sure. I guess I just kinda got used to guessing the proper variable.
And I think I'd call it a length element in this case. ;)
cookiemonster
x(t)=0t3+9t2+36t
y(t)=-1t3-6t2+15t
formula is correct may be u are following a wrong procedure or making some wrong moves in between
[tex] \frac{dx}{dt}= 18(t+2)[/tex]
[tex] \frac{dy}{dt}= -3(t^2+4t-5)[/tex]
so u have length of curve
[tex]s = \int_0^1{\sqrt{t^4+42t^2+32t+8t^3+169}}dt[/tex]
yes...that was the formula i meant outandbeyond...
and thanks 4 the help...now i jst have 2 factor that rite..
ok...im not gettin newhere with this problem...if ne1 has ne suggestions that would b awesome
Are you sure they didnt ask you to integrate a function along that path. For instance finding the weight of a wire if given a function for its density.
What's the answer that you're getting? Or are you having trouble evaluating the integral?
cookiemonster
ok i got it...i was having problems with integrating but i figured it out...thx 4 all the help...much appreciated!
