Earth's Atmospry: Heavier Elements, N2, O2, CO2, H2O
  • Thread starter Thread starter pivoxa15
    Atmosphere
The Earth's atmosphere consists of a mixture of gases, with nitrogen (N2) being the most abundant. Heavier elements like carbon dioxide (CO2) and oxygen (O2) are found closer to the Earth's surface, while water vapor (H2O) exists both near the surface and at higher altitudes, contributing to cloud formation. The white color of clouds is attributed to Mie scattering, which occurs due to the presence of small water droplets. Below 100 km, molecular forces and turbulent mixing prevail, while above this altitude, gravity becomes the dominant force affecting gas distribution.
  • Understanding of atmospheric composition and gas behavior
  • Knowledge of Mie scattering and its effects on light
  • Familiarity with molecular scale forces and turbulent mixing
  • Basic concepts of gravity's influence on gas distribution
  • Research the principles of Mie scattering in atmospheric science
  • Explore the role of molecular forces in gas behavior
  • Study the distribution of gases in the Earth's atmosphere above 100 km
  • Investigate the impact of water vapor on weather patterns and cloud formation
Atmospheric scientists, meteorologists, environmental researchers, and anyone interested in the composition and behavior of Earth's atmosphere.
pivoxa15
The heavier elements tend to be found near Earth's surface than the lighter ones. However the most widely found element is N2 but elements like CO2 and O2 are other heavy ones so more near the Earth's surface? What about water? Is water mostly near Earth's surface or way above? If way above, is that why clouds are way above us and they are made out of water vapour?
Why is O2 clear and H2O which is lighter, white coloured in gas form? Is it because of the stronger intermolecular bonding between H2O?
Chemistry news on Phys.org
CO2, N2 and O2 are not so different in weight so they mix well in the atmosphere. H2O vapor is even lighter than those gases. The clouds are made of water small droplets not only water vapour so the cloud's white colour is due to scattering effect, the Mie scattering.
The Earth's atmosphere is a nearly uniform gaseous solution from sea level to about 100 km. Molecular scale forces and turbulent mixing dominate over gravity below this level. Above the 100km level, the long mean free path means gravity dominates over brownian motion and turbulence.
  • · Replies 19 ·
11K
  • · Replies 21 ·
