How can I prevent unexpected restarts in Windows XP?
  • Thread starter Thread starter wormhole
The discussion revolves around the issue of unexpected restarts in Windows XP, focusing on user experiences and potential solutions. Participants share their frustrations and explore the behavior of the operating system in response to certain actions, such as uninstalling components or changing settings.
  • One participant expresses frustration over Windows XP restarting unexpectedly after uninstalling a component, seeking a way to prevent such restarts or to receive explicit permission before restarting.
  • Another participant suggests that the operating system is functioning as intended, implying that unexpected restarts may be a normal behavior of Windows XP.
  • A different participant, while not intending to insult, questions whether the original poster might have a trojan or worm causing the issue, indicating that they have not experienced similar problems in three years of use.
  • One participant notes that changes to settings or software installations often require a restart, acknowledging that while a prompt usually appears, it does not always offer the option to restart later.
  • Another participant suggests that users should save their work and close programs before initiating actions that may lead to a restart, although they recognize the annoyance of this requirement.
  • A participant shares a personal anecdote about their experience with Windows 98, highlighting frequent crashes and contrasting it with the current discussion about Windows XP.
Participants do not reach a consensus on the cause of the unexpected restarts, with some suggesting it is normal behavior while others raise the possibility of malware. The discussion remains unresolved regarding effective solutions to prevent such restarts.
Participants mention the importance of saving work before performing actions that may lead to restarts, but there is no agreement on whether the operating system should provide better prompts or options for users.
wormhole
it's driving me crazy...
anyone knows how can i prevent my windows xp from restarting??
there are situations when you click some button in some window and it
restarts the system without asking first
everything is fine with windows no virusesand restart is more or less expected
why i say "more or less"?
for example 2 minutes ago i uninstalled some windows component which i got from windows update site and now i don't need it... so uninstall finished and message box appeared saying something like "i probably will need to restart my computer" and only one button "OK' on it.
so i hit ok assuming that the system will pop up messege box to ask me if i want to restart now or later...
but instead windows restarted with no care that i have a bunch of programs working...
so i looking for some way to prevent restart that already begun or to force system in all cases explicitly ask my permission to restart
Computer science news on Phys.org
It sounds like your specified operating system is working exzctly as it was made to ( yes I use windows also )
I've been using Windows XP for 3 years and I've never had such a problem.
Not to insult your intelligence but is it possible that you have a trojan or worm?
Wormhole, as you've discovered, changes that you make to settings, installing new software, etc... will often require windows to restart before they can take affect.
And as you mentioned, usually you will get a pop up box with the option to restart later, but apparently not always.
It's usually a good idea to save and close out of whatever you are doing before you do these things otherwise you could lose unsaved information.
I know it's a nuisance if you are doing a lot, but a little planning ahead and patience on your part is your best bet.
Um.. you could've closed your programs befóre hitting the 'OK' button? I know though.. it can be annoying. I was working on a windows 98 computer not too long ago, but I wrote it off for the scrap yard. It used to crash on me every 15 min and it would take about the same time to get it running again
Yeah Windows 98 sucked. I used to keep a log of how often it crashed. It averaged about 3 times per day and the most common thing that would happen is when the screen goes all blue with no words. With BSOD you get words telling you to do something, but my computer would just go blue with no words. Sometimes it would also just go all black.
13K
12K
  • · Replies 17 ·
  • · Replies 34 ·
  • · Replies 24 ·
