Local extension and differential geometry
The discussion centers on proving that the map g: torus → S² is a C-infinity map. The torus is parameterized by x(u,v), y(u,v), and z(u,v) functions. The map g is defined as g = [6yz/(x²+y²+z²+8), 3-sqrt(x²+y²), -xz/sqrt(x²+y²)]. To establish that g is C-infinity, the user must create local extensions of coordinate maps between open subsets of R³, utilizing a partition of unity. This approach simplifies the proof of the original map's smoothness.
  • Understanding of C-infinity maps in differential geometry
  • Familiarity with parameterization of surfaces, specifically the torus
  • Knowledge of local extensions of functions in topology
  • Experience with partitions of unity in manifold theory
  • Study the concept of local extensions in differential geometry
  • Learn about partitions of unity and their applications in manifold theory
  • Explore coordinate maps and their significance in proving smoothness
  • Investigate the properties of C-infinity maps and their implications in geometry
Students and researchers in mathematics, particularly those focusing on differential geometry, manifold theory, and smooth mappings. This discussion is beneficial for anyone tackling assignments related to smoothness of maps between manifolds.
Hyperreality
I have to prove the map g:torus --> (S^2 3 dimensional sphere of radius 1) is a C infinity map in my assignment.
The torus is parameterized as
x(u,v)=(3+cos u)(cos v)
y(u,v)=(3+cos u)(sin v)
z(u,v)=sin u
The map g is given by
g=[6yz/(x^2+y^2+z^2+8), 3-sqrt(x^2+y^2), -xz/sqrt(x^2+y^2)]
I have done that by using suitable coordinate maps. But I am terribly confuse in how to prove this by choosing suitable local extensions between open subsets of R^3. To be honest I don't really know the definition of local extension of a coordinate map!
All I know is about local extension is that for f:u1 -> u2, local extension of f is F:U1 -> U2 such that u1 is a subset of U1 and u2 is a subset of U2, I am not sure if f has to equal F (f=F).
I think this can be proven easily if I just local extend g to G:R^3 -> R^3 where g=G and it is obvious that G is C-infinity then so does g. But how do I do this by choosing local subset of R^3, I don't really have a clue.
That's a great question! It's definitely tricky to prove a map is C infinity, but the good news is that there are some steps you can take to make it easier. First, you'll need to define a coordinate map that takes the torus to R^3. Once you've done that, you'll need to create local extensions of your coordinate map between open subsets of R^3. To do this, you can use a partition of unity to construct local extensions of your coordinate map that are defined on open sets in R^3. After you have your local extensions in place, you can then use them to show that the original map is C infinity. Hopefully this helps and good luck with your assignment!
  • · Replies 27 ·
