Calculating Car Brake-Pedal Force for Desired Braking Distance
  • Thread starter Thread starter johnny_heart
    Car Force
The discussion revolves around formulating a relationship between the initial velocity of a car, the force applied to the brake pedal, and the desired braking distance. Participants explore the mechanics of braking systems, including hydraulic systems and the role of friction in braking force.
  • One participant seeks a mathematical formulation linking initial velocity, brake pedal force, and braking distance, mentioning existing equations related to forces in the brake system.
  • Another participant questions the linearity of braking force with respect to pedal force, noting that modern systems may not behave in a straightforward manner due to hydraulic or drive-by-wire technologies.
  • Concerns are raised about the variability of average foot force, with one participant suggesting that using a single measurement may be insufficient.
  • A suggestion is made to create or adapt a pressure transducer pad to measure force on the brake pedal during braking.
  • Discussion includes the impact of power brakes and the potential need to disconnect the vacuum line to measure real forces, with safety cautions emphasized.
  • Participants express differing experiences with brake responsiveness, indicating that the relationship between pedal pressure and braking force may vary by vehicle manufacturer.
Participants express differing views on the linearity of braking force relative to pedal force and the effectiveness of various measurement techniques. There is no consensus on the best approach to accurately determine the required foot force for braking.
Limitations include the dependence on specific vehicle designs and braking systems, as well as the variability in foot force measurements. The discussion does not resolve the complexities of hydraulic systems or the influence of additional braking technologies.
This discussion may be of interest to automotive engineers, physics students studying dynamics, and hobbyists exploring vehicle performance and braking systems.
johnny_heart
Car brake-pedal force...
Hey all,
im posting because i would like suggestions (preferably with proof) on how a relationship between initial velocity of a car, force to brake pedal and desired braking distance can be formulated. Assuming we know the velocity and the desired braking distance from this initial velocity?
so far i have the equations for forces going through the brake system but only once a foot force is generated.
for example,
biasForce = footforce*Ag
where Ag = mechanical advantage of pedal (found by taking moments about the pedal axis)
biasForce = force transmitted to bias bar.
After this I have pressures generated at master cylinder etc, but id like some references to where I can find a suitable equation to calculate the needed foot force. My idea was to take real tests, and set up a table, but I haven’t managed to get hold of a device which I can strap to my foot, while I am braking in my car!
any help appreciated,
jOn
I'm not sure braking force is linear with pedal force anymore, since they are hydraulic or drive-by-wire (not sure if there is much of that), but friction on the brakes is directly proportional to the force between the brake pads and the rotors.
Im ok with the frictional forces for now,
some sources say average foot force is 100Ibf but it seems a bit vague to use just one force measurement.
if anyone has any suggestions for working this out mathematically please let me know,
otherwise my best bet is to try and find a measuring device which can take readings while I am braking and use that data
thanks jOn
It shouldn't be too difficult to find or make a pressure transducer pad that can fit over the brake pedal. Perhaps an old-style trailer brake controller can be adapted for that purpose. I seem to recall that some of them were proportional (but I'm not sure).
nearly all cars have power brakes
run off engine vacuum thru a brake booster
if you want real forces you would need to disconnect the vacuum line to the booster SIMPLE AND EAZY BUT THAT KILLS MOST OF THE BRAKEING FORCE
NOTE DONOT TRY THIS ON THE ROAD, MAYBE A EMPTY PARKING LOT
and only at very low speeds BE SAFE
Good advice, Ray, but I don't know that you'd have to disconnect the boost. Since it's proportional to the pedal pressure, you should be able to compensate for it.
I don't know - I've driven cars with touchy brakes and "soft" brakes. It seems to me that though it would make sense to make them proportional, but I don't know that they realistically are.
Maybe. All of mine have been, but it probably depends upon the manufacturer. Also, none of mine had any ABS or other weird stuff.
lol, thanks for the replies,
going a bit off the topic but...
ill probably just use a variety of forces starting at about 100Ibf.
jOn
  • · Replies 42 ·
12K
