Does the Series \( a_n = \frac{2^n}{\sum_{k=1}^n \frac{1}{k}} \) Converge?
  • Context: Undergrad
  • Thread starter Thread starter sutupidmath
    Convergence Series
The discussion revolves around the convergence of the series \( a_n = \frac{2^n}{\sum_{k=1}^n \frac{1}{k}} \) as \( n \) approaches infinity. Participants explore various methods and reasoning to determine whether this series converges or diverges, including the use of the ratio test and comparisons to known divergent series.
  • Some participants express uncertainty about rewriting the series and whether it affects convergence analysis.
  • One participant argues that since \( 2^n \) grows faster than the harmonic series in the denominator, the sequence diverges to infinity.
  • Another participant suggests using the ratio test to analyze convergence but acknowledges difficulties in simplification.
  • There are discussions about the notation and how to express the general term of the series.
  • Some participants propose comparing the series to known divergent series to support their claims about divergence.
  • One participant emphasizes that if the last term of the series is greater than zero, the series cannot converge.
Participants generally agree that the series does not converge, but there are multiple approaches and reasoning presented, and no consensus on a single method of proof is reached.
Participants express confusion regarding the notation and the proper way to write the general term of the series. There are also discussions about the implications of the harmonic series diverging and how it relates to the convergence of the given series.
This discussion may be useful for students and individuals interested in series convergence, mathematical reasoning, and those seeking clarification on the application of convergence tests.
sutupidmath
convergence of a series. NEED HELP!
i am sorry for my symbols, but i can't use latex yet.
i have this series a_n=2^n/(1+1/2+1/3+1/4+...+1/n), and i am asked to find the convergence of this series when n goes from 1 (n=1) to infinity.
I have done this series, however i am not sure if i can go here, i do not know if i can rewrite the given series in this form, and not to change anything, so it would be:
a_n=2^n/(1/n), when n goes from 1 to infinity. If i am right here, then the rest is all clear to me.
any help would do. SO what do you guys think?
I don't see how you can possible think that 2n/(1/n)= n2n is the same as what you give above. In any case, it seems clear to me, since 2n increases much faster than n while 1+ 1/2+ 1/3+ ...+ 1/n increases slower than n, that the sequence an goes to infinity and, therefore, the series (the sum), if that was what you meant, does not converge.
yeah i also think it cannot converge, but how can i show it then?
I mean how can i come to that conclusion in a more elaborated way??
can you give me some hints then? Because look here what would be the partial sum for example let's say when we take n=1, then n=2, it looks a little weird to me writin let's say when we take n=1
S_1=2^1/(1+1/2+1/3+...+1/1)
it looks a little weird doesn't it??
Do you mean:
a)[tex]\sum =\frac{2^1}{1}+\frac{2^2}{1+\frac{1}{2}}+\frac{2^3}{1+\frac{1}{2}+\frac{1}{3}}+...[/tex]
OR perhaps
b)[tex]\sum =2^{\frac{1}{1}}+2^{\frac{2}{1+1/2}}+2^{\frac{3}{1+1/2+1/3}}+...[/tex]
Something else?
Anycase,both are divergent becouse :
[tex]\lim_{n\to \infty}a_{n}>0[/tex]
Also consider the ratio test: if [tex]a_(n+1)/(a_n) >1,[/tex] the series diverges; [tex]if a_(n+1)/a_n =1,[/tex]result unknow; if [tex]a_(n+1)/a_n<1[/tex] the series converges.
yeah i have tried this. It is also called dallamber's rule of convergence. but the way it is given as i OP-ed, i cannot really simplify, or at least have no idea how to simplify.
tehno said:
Do you mean:
OR perhaps
Something else?
i took that serie as it it originally written in the book. the proffesor put it on an exam once.
so it is a_n=2^n/(1+1/2+1/3+...+1/n), when n goes from 1 to infinity.
the thing that appears to be a prob to me, and that looks very weird, is the denominator. because how would you rewrite this when n=1?, so i mean the partial sum of this series when n=1??
can anyone else give some more hints?
Ok well we know that the harmonic series
[tex]\sum_{n=0}^{\infty} \frac{1}{n}[/tex] diverges. Look on wikipedia for a proof. Since that sum diverges to positive infinity, n over that sum is 0. 2^0 is 1, larger than zero. Does not converge. A must longer and stupider way than tehno's.
tehno said:
Do you mean:
how would you write the general term for this series
i mean
a_n=?
yeah i know the proof for 1/n .
but here n goes from 1 to infinity not from 0.
Moreover, i do know that this series does not converge, however what i am lookin for is a way, an elaborated way, to come to that conclusion.
In any case i am not following you here Gib Z. Can u give more explanations, maybe it will be boring for u but i just don't get it!
Stupid, no??
Notation?
sutupidmath said:
how would you write the general term for this series i mean
a_n=?
sutupidmath ,that infinite sum can be formally written as:
[tex]\sum_{n=1}^{\infty}\frac{2^n}{\sum_{i=1}^{n}(1/i)}[/tex]
Did you denoted by a_n ,n-th partial sum ?.Usually partial sum is denoted by s_n.Please try by yourself ,after this, to see the notation for the partial sum.
However,I think that the notation is the least important here.
Stupid, no??
Really, tehno already answered your question, but here's my long way:
A series can not converge if the "last" term is more than zero. I think you already know that. So to prove that this series you have doesn't converge, we can see that in the final term, there will be [tex]2^\frac{n}{\sum_k^{\infty} \frac{1}{k}}[/tex]. The denomiator doesn't converge, and diverges to infinity.
n divided by infinty is 0. 2^0 is 1. The final term is not 0, it is 1.
It doesn't converge.
Actually I just realized my response was to tehno's shown form of b and you wanted A.
My answer is compare it to the smaller series I am giving here, and show that diverges.
When we divide the numerator of the term by a larger number, the term is overall smaller. So eg for n=3, a smaller term than
[tex]\frac{2^3}{1 +1/2+1/3}[/tex] Is [tex]\frac{2^3}{1+1+1}[/tex]. In other words, divide by the larger series to get a smaller term by term. Since we can see that [tex]\frac{2^n}{n}[/tex] when n approaches infinity is obviously more than zero, so it doesn't converge.
thank you all guys, in particular you Gib Z, because this is exactly what i was looking for. thnx again.
No problem, but next time if you really want to learn instead of having things pointed out to you, go with tehno's advice, it was really good advice.
yeah, i really do appreciate tehno's advice and help, but i got a little confused so i needed some more hints. However i will give more effort other times, in solving problems by myself. thnx again
  • · Replies 19 ·
