Diffraction from a circular aperture
The discussion focuses on calculating the diameter of a laser beam from a ruby laser (\lambda = 694.3 nm) after it travels 10,000 km, considering diffraction through a circular aperture. The relevant equation used is sin(θ) = 1.22λ/D, where D is the diameter of the laser beam (14 cm). The initial calculations suggest a resultant diameter of approximately 1.65 x 1012 m at the target, although participants express uncertainty about the accuracy of this result and the methodology used.
  • Understanding of diffraction principles and the circular aperture effect
  • Familiarity with the ruby laser specifications and wavelength calculations
  • Basic trigonometry for calculating angles and distances
  • Knowledge of the Pythagorean theorem for distance calculations
  • Study the derivation of the diffraction pattern from circular apertures using the Airy disk formula
  • Learn about the impact of laser beam divergence on long-distance propagation
  • Explore the concept of the Rayleigh criterion in optical systems
  • Investigate the effects of atmospheric conditions on laser beam propagation over long distances
Students and professionals in optics, physics, and engineering who are involved in laser technology, particularly those interested in beam propagation and diffraction effects.
Brewer
A ruby laser ([tex]\lambda[/tex] = 694.3nm) is aimed in free space at a target 10,000km away. If the laser beam is initially 14cm in diameter, how large will its diameter be when it hits the target taking account of diffraction at the circular aperture of the laser?
I think:
sin[tex]\theta[/tex] = 1.22[tex]\lambda[/tex]/D
sin[tex]\theta[/tex] = opp/hyp = x/r
therefore:
sin[tex]\theta[/tex] = 1.22[tex]\lambda[/tex]/D = x/r
===> r= xD/(1.22[tex]\lambda[/tex]), which after plugging in the numbers gives r = 1.65 * 10^12 m.
Then by a bit of Pythagoras it can be found that y(the diameter) = 1.65 * 10^12m.
Now I'm not sure about this. I couldn't find an equation in my notes or textbook that seemed to explain this entirely. However the equation given says that 85% of the light is in the first circular maximum, so I thought it would be a valid assumption to assume that this would be the diameter of the image formed. I also have trouble believing my answer. It seems a little large, and I don't know if I've approached it the correct way either.
Any comments and/or hints would be appreciated.
Brewer
I think your approach is basically right, but I'm confused about your equation for "r". What is x? I think you can use your relevant equation to find the angle of the beam as it leaves the aperture. After that, use trig to find out what the size is on the screen.
I get a different answer than you (I'm not saying mine is right), but I'm having trouble understanding your solution. Could you show more detail in you work?
I'll scan in my work and post it in a minute or two. Thanks for reading this by the way.
11K
