Low Frequency Signal Processing - Filtering DC Offset
  • Thread starter Thread starter PoisoN_83
    Frequency Signal
This discussion focuses on eliminating DC offset from low-frequency signals, specifically in the 0.2Hz to 5Hz range, using high-pass filters (HPF). Participants recommend using a capacitor, such as a 1000 µF capacitor, to block DC voltage while allowing AC signals to pass. Alternatively, an op-amp-based high-pass filter can be employed for more precise control. For digital signals, implementing a simple digital high-pass filter routine is advised to effectively remove the DC offset.
  • Understanding of high-pass filter design
  • Knowledge of capacitor selection and impedance
  • Familiarity with operational amplifiers (op-amps)
  • Basic concepts of digital signal processing
  • Research analog high-pass filter design using op-amps
  • Learn about capacitor selection for low-frequency applications
  • Explore digital high-pass filter algorithms and implementations
  • Study the effects of DC offset in signal processing
Electronics enthusiasts, signal processing engineers, and anyone involved in filtering low-frequency signals to remove DC offsets.
PoisoN_83
Hello!
I´m new here and need a little help with some electronics.
I have signals with information in the 0.2Hz - 5 Hz range (breath signal) with a DC offset of about 3V (not constant).
I want to eliminate this offset voltage but still don´t change the original information.
What type of highpass filters can I use for this application?
How should I think?
Information about both analog and digital filter of this type is interesting.
Thank you!
You just need to run the signal through a capacitor. DC voltage will be blocked and AC will run right through. For low frequencies you need more capacitance to minimize its impedance. A 1000 uF cap would do.
Or if you want to use a smaller capacitor, just make an opamp-based highpass filter.
And if you can just digitize the signal, then you can write a simple digital HPF routine as you suggest to get rid of the slowly-varying DC offset.
http://en.wikipedia.org/wiki/Electronic_filter
  • · Replies 48 ·
  • · Replies 24 ·
