Adding two lines, what is the equation of the new line?
  • Thread starter Thread starter saplingg
    Line Lines
The problem involves finding an equation that relates the speed of a vehicle to its overall distance, which is the sum of thinking distance and braking distance. The original poster has derived equations for speed in relation to both thinking distance and braking distance using graphing software.
  • Exploratory, Assumption checking
  • The original poster attempts to combine two separate equations for speed related to thinking distance and braking distance to derive an overall equation. Some participants question the notation used for distances and the need for units on constants.
The discussion includes attempts to clarify the notation and the context of the problem. There is a suggestion to ensure clarity in the variables used. The original poster indicates they have resolved the issue, but the details of that resolution are not provided.
There is a mention of potential confusion due to the use of the same letter for different types of distances, which may affect understanding. The original poster's title references "ADDING two lines," which some participants note as relevant to the discussion.
saplingg
Basically I was given a table displaying speed of a vehicle, thinking distance (distance it takes for driver to react) and braking distance. I am told to find an equation relating speed of vehicle and overall distance (overall distance = thinking distance + braking distance).
Using graphing software, I've managed to find an approximate equation relating speed and thinking distance, as well as an equation relating speed and braking distance.
The equations are :
For speed vs thinking dist., y = (16/3)x, where y is speed of vehicle and x is thinking distance
and
For speed vs braking dist., y = 13(x^0.5), where y is the speed of vehicle and x is braking distance
Is there any way I can find an equation for speed versus overall distance using these 2 equations that I've obtained?
Sure. It might be more obvious if you didn't use the same letter to denote thinking distance and braking distance.
(And shouldn't those constants have some units on them?)
Could anyone show me how?
@Hurkyl: I used subscripts to distinguish the distances
You are talking about the TOTAL distance aren't you?
(And you titled this "ADDING two lines"!)
yeah what is wrong with that?
Err It's ok, I've solved it. Thanks to all who read
