Finding the limit and a differential equation
The discussion revolves around finding the limit of a solution curve for the differential equation dy/dx = y - 2y^2, specifically for a curve passing through the point (0, 0.25). Participants explore methods for solving the equation and determining the limit as x approaches infinity.
  • Exploratory, Technical explanation, Debate/contested, Mathematical reasoning
  • One participant expresses difficulty in finding the function f(x) by separating variables and integrating 1/(y - 2y^2).
  • Another suggests using partial fractions to integrate 1/(y - 2y^2) as a potential solution.
  • A different participant derives a solution y = 1/(e^-x + 2) + C and notes that without the constant C, the limit approaches 1/2, but with C = -1/12, the limit becomes 5/12, which does not match any provided answer choices.
  • One participant challenges the correctness of the derived solution and encourages checking the work for potential errors.
Participants do not appear to reach a consensus on the correct solution for y(x) or the limit as x approaches infinity, with differing results and interpretations of the constant C's impact on the limit.
There are unresolved mathematical steps regarding the integration process and the influence of the constant C on the limit, which may affect the final conclusions drawn by participants.
cokezero
i can't seem to figure this out...
if the differential equation dy/dx= y-2y^2 has a solution curve y=f(x) contianing point (0, 0.25) , then the limit as x approaches infinity of f(x) is
a)no limit
b. 0
c. 0.25
d. 0.5
e. 2
i usually just separate the variables and find f(x) then take the limit, but i can't seem to find f(x) b/c it would require the integral of 1/(y-2y^2)
so, integrate [itex]\frac{1}{y-2y^2}[/itex]! Partial fractions will do it.
yeah i know...
i get the equation
y= 1/(e^-x + 2) +C
without the c value it is 1/2 for the limit
but with the c value which is -1/12 i get a limit of 5/12 which is not an answer choice...
so the question becomes, does the limit depend on the c value or not?
That's not the answer I get for y(x). Try checking your work again. If you still can't figure it out, post what you've done and I'll try to tell you what's wrong!
  • · Replies 0 ·
