Can the formula for G be used to measure gravity using a mass and spring system?
  • Context: High School
  • Thread starter Thread starter sharpy
    Formula
The discussion centers around the feasibility of measuring the acceleration due to gravity (g) using a mass-spring system. Participants explore the relationship between the period of oscillation, mass, spring constant, and gravitational force, considering both theoretical and practical aspects of the setup.
  • One participant expresses difficulty in using a mass attached to a spring to measure g, despite having the period of bounce, mass, and elastic constant.
  • Another participant argues that the period of motion is independent of g, stating that the period is given by 2π√(m/k) and does not involve g.
  • Some participants suggest that the mass could affect the period due to gravity, raising questions about the relationship between mass, spring constant, and gravitational force.
  • A participant proposes using the formula for a simple pendulum, but later acknowledges the mistake, realizing the setup involves a spring, not a string.
  • There is a suggestion that the elastic constant of the spring could relate to the restoring force, which might be analogous to the force of gravity acting on the mass.
  • One participant mentions a formula involving the period and lengthening of the spring, suggesting it could yield a value for g, but this is met with skepticism from others.
  • Another participant insists that the period of oscillation does not depend on gravity, emphasizing that the spring and mass system behaves the same regardless of gravitational conditions.
  • Discussions about static measurements versus dynamic oscillations arise, with some participants advocating for measuring static deflection to find g more directly.
  • Clarifications are made regarding the definitions of variables, such as distinguishing between static deflection and the total length of the spring.
  • One participant admits to confusion regarding the elastic constant and its relationship to the measurements being taken.
  • There is a consensus that measuring the extension of the spring when a mass is applied is crucial, but the precision of such measurements is questioned.
Participants do not reach a consensus on the validity of using the mass-spring system to measure g. Multiple competing views remain, particularly regarding the role of gravity in the oscillation period and the appropriateness of static versus dynamic measurements.
Participants express uncertainty about the definitions and relationships between variables, such as the elastic constant and gravitational force. There are unresolved questions about the precision of measurements and the assumptions underlying the proposed formulas.
This discussion may be of interest to those exploring experimental methods for measuring gravitational acceleration, as well as students and enthusiasts of physics and engineering looking for insights into oscillatory motion and spring dynamics.
sharpy
ok, I am trying to measure thevalue of g using a mass attatched to a spring. i have the period of bounce, the mass of the..well...mass, and the elastic constant of the spring. i have been informed its relatively easy to find g using this setup but I am struggling. iv spent the last 3 nights either rearranging formulae or serching the internet and my brains dead and i really need a break from this. anyone? any help like atall is massivley appreciated. though as usual the answers probably pretty obvious and I am jst being blind. but thanks anyway.
The period of motion is not dependent on g and so cannot give a value for it.
The motion of a weight on a spring, assuming it is hanging, is given by the differential equation
[tex]m\frac{d^2 x}{dt^2}= -kx- mg[/tex]
or
[tex]\frac{d^2 x}{dt^2}= -\frac{k}{m}- g[/tex]
The general solution to that is
[tex]x(t)= C_1 cos(t\sqrt{\frac{k}{m}})+ C_2 sin(t\sqrt{\frac{k}{m})- frac{g}{k}[/tex]
The period is given by
[tex]2\pi\sqrt{\frac{m}{k}}[/tex]
with no dependence on g.
Of course, you have mg= kx where x is the "stretch" when you hang the weight on the spring initially so g= kx/m. That's done with the spring motionless.
...but the period is dependent on the mass which can be affected by altering gravity?
i know I am grasping at nothing but I am pretty sure my friend managed this and I am pretty stubborn about not failing when I've wasted so much on this
How about
[tex]T = 2 \pi \sqrt{\frac{L}{g}[/tex]
EDIT: Whoops. Never mind. If I passed basic reading comprehension I would have noticed that you said a mass on a spring, not a string. Don't mind me.
would this work? what could i use for l?
i still have mass and spring elastic to use up.
i didnt really measure anything else :frown:
FredGarvin said:
How about
Which is for a simple pendulum, not a mass on a spring (as FredGarvin certainly knows).
simple pendulum indeed, however ill use anything. i am definetley that desperate.
surley it would be possible somehow to use the elastic constant of the spring to find the restoring force which would be somewhat the same as the force of gravity acting on the mass? no? anyone?
Maybe the catch is to use the period [tex]T[/tex]of the oscillation and the lengthening [tex]\ell[/tex] of the string:
[tex]g = \ell\left({2\pi\over T}\right)^2[/tex]
(if I didn't did a mistake)
omg thankyou I am getting aroundabout 9 for my value of g, and since my technique can be considered fairly crude i will have to assume that this is the best formulae ever concived. thankyou much, and my mum thanks you as i hae stopped sulking about not being able to work this out. thanks to you all though, i realize your time is important so thanks for even reading the post, but to the guy who posted that formulae i owe my life. :!)
... any chance of a proof for this? :smile:
but really thankyou
im so happy:biggrin:
my easter holidays might not be ruined afterall
......no. What he told you is wrong and you got a close answer by dumb luck. The period of oscillations has nothing to do with g. Read the very first post and what HallsofIvy told you.
:( i feared this day would come
are you sure?
i know someone who has done this before and I am convinced that there's a way. sure it was dumb luck? i tried it on all of my readings and they were all pretty much right. its late where i am and I am tired and i can't work out if they all would be right from just luck
could this not work then since the mass in the spring constant cancels with the mass in the shm equation so that i can match the extension to the period o the same masses? i really don't know. ill be quiet now.
Read HallsofIvys post. Gravity does not play a role in SHM of a spring. Are you talking about a spring or a string?
...yeh i read that and was disheartened, however
t=2pi root m/k
and
w^2 = k/m = g/e
so can't we change this to
t=2pi root e/g
...which means that the period can be dependent on gravity?
no?
i know hallsofivy said that it didnt but why couldn't this work?
thanks for your patience
and the fast response that was awesome cheers
and yeh sorry definitely a sPring
w^2 = k/m = g/e
where did this come from?
The answer is no. The spring and mass does not depend on gravity, ever. You can take it to the moon and you will get the same answer. You can turn gravity off and still get the same answer.
...ok... erm...
i have it written in a book, and i think its because the whole hookes law thing gives f = kx and f = ma gives xk = ma
a as the acceleration can substitute for g
and e for extension because its easier that way
so we have
mg = ke
and then we rearrange or something to get
k/m = g/e
...maybe?
I do not know if I make it clear.
When you hang a mass m the spring lengthens of [tex]\ell[/tex]:
[tex]mg=k\ell[/tex]
If you put the mass and the spring in oscillation the period is:
[tex]T=2\pi\sqrt{m\over k}[/tex]
then:
[tex]{k\over m}= \left({2\pi\over T}\right)^2[/tex]
From the first formula:
[tex]g=\ell{k\over m}[/tex]
[tex]g = \ell \left({2\pi\over T}\right)^2[/tex]
OK?
This is not a pendulum lpfr. (And please delete one of your double posts.)
Do I say it was?
It is a mass at the extremity of a spring and it oscillates VERTICALLY!
I see what your doing now, but its still rather meaningless because your calling [tex]\ell[/tex], what should really be called [tex]\Delta L[/tex] and that is a STATIC measurement of the physical system. Its exactly measuring the displacement of the mass. You don't need SHM to do that. All you have to do is put the mass on and measure the deflection. Its a static experiment.
see what I mean?
...well i don't know how to do a fancy l anyhow
so your agreeing it will work?
or do the physiics wars continue?
Although...that is a very clever way of finding g by eliminating the need to find the spring constant k altogether! :smile:
(Though it would be much more inaccurate)
...so its all good?
Yes, that's fine, but l is the static deflection of the mass on the spring.
NOT the entire length of the spring.
yeh cool l is the extension when loaded yesss.
i was going to try the static one but then the forces and stuff would require me changing mass to weight apparently? and id have to use g for that which is why we went for the difficult one
well anyway thankyou very much guys youve been wonderfull.
Say that again?
make sure you use the static deflection.
hahaha never mind I am babaling now.
thanks for the help.
goodnight.
Are you looking for g or G? I'm assuming you mean gravity, not the gravitational constant, by reading some posts.
Anyway, it's pretty much just avoiding the situation, but you could just put a mass on a spring and measure how much the spring has changed in size (assuming you know the k for that spring).
i was trying to find the gravitational field strength.
i did however make a mistake stating that i had the elastic constant , as i only had a table of mass against extension, and I am now under the impression that the elastic constant requires weight against extension? so to find the elastic constant id need to know g which I am trying to find.
so i cant.
If you use the formula that I posted, the only thing you need to measure is the stretching (the lengthening) of the spring when you hang the mass.
To know the weight you need to know g and this is what you are looking for.
You do not need to have a table of extensions against masses. You just need the extension for the mass you use to measure the period of oscillation.
Do no expect to obtain g with high precision. The measure of the extension is not very precise and the measure on period is not much better.
  • · Replies 19 ·
