Calculate K at 100 C for Reaction of Ethanol and Acetic Acid
  • Thread starter Thread starter Orbit1212
    Rate Reaction
The discussion focuses on calculating the equilibrium constant (K) for the reaction between ethanol and acetic acid at 100°C. Given the initial concentrations of both reactants at 0.810 M and the equilibrium concentration of acetic acid at 0.748 M, the calculation involves applying the formula for pseudo first-order kinetics. The reaction is represented as C2H5OH (aq) + CH3COOH (aq) <=> CH3COOC2H5 (aq) + H2O (l). The value of K can be determined using the equation kt=ln(a/(a-x)), where t is the temperature in Kelvin.
  • Understanding of chemical equilibrium concepts
  • Familiarity with the reaction kinetics, specifically pseudo first-order kinetics
  • Knowledge of equilibrium constant calculations
  • Basic proficiency in logarithmic functions and temperature conversions
  • Study the derivation and application of the equilibrium constant (K) in chemical reactions
  • Learn about pseudo first-order kinetics and its implications in reaction rates
  • Explore temperature effects on equilibrium constants and reaction rates
  • Investigate the use of the Van 't Hoff equation for temperature dependence of K
Chemistry students, chemical engineers, and researchers interested in reaction kinetics and equilibrium calculations will benefit from this discussion.
Orbit1212
I have this problem to solve and I am having dificulity it doing so:
An aqueous solution of ethanol and acetic acid, each with a concentration of 0.810 M is heated to 100 C. At equilibrium, the acetic acid concentration is 0.748 M. Calculate K at 100 C for the reaction.
This isn't for homework or anything like that. I am just going back through old college textbooks and came across this one.
Thank you for help in advance.
I think this reaction follows pseudo first order kinetics, so [tex]kt=ln\frac{a}{a-x}[/tex]. You have t=373k, a=.810 a-x=0.748, solve for k.
