Confused about invariant mass in particle collision
The discussion centers on the concept of invariant mass in particle collisions, specifically when positrons collide with stationary electrons to produce proton-antiproton pairs. The total energy is calculated using the equation E = T + Mc², where M represents the invariant mass, equating to 2 times the rest mass of a proton (2 * 938 MeV). Participants clarify that while invariant mass is typically not additive, in this scenario, it is appropriate to sum the masses due to the conditions of the collision, particularly when kinetic energy (T) is zero.
  • Understanding of relativistic energy equations, specifically E = T + Mc²
  • Familiarity with the concept of invariant mass in particle physics
  • Knowledge of particle collision dynamics and energy conservation
  • Basic understanding of proton and antiproton properties, including rest mass (938 MeV)
  • Study the derivation and applications of the invariant mass formula in particle physics
  • Learn about relativistic momentum and its role in particle collisions
  • Explore the implications of energy conservation in high-energy particle collisions
  • Investigate the differences between invariant mass and rest mass in various collision scenarios
Physicists, students of particle physics, and anyone interested in understanding the principles of energy and mass in high-energy collisions.
iacephysics
Ok, when you use positrons to shoot at stationary electrons in a collider with enough energy so that you make a pair of proton and antiproton. The total energy of the pair would be E = T + MC^2, where M is the total invariance mass of the pair, namely 2*938Mev, or I can use E^2 = (pc)^2 + (Mc^2)^2, and M here is still the invariant mass. I got the correct answer using M = 2 times the mass of the rest mass of a proton, as said previous, 2*938 Mev. What I am trying to understand here is why the invariant mass here is the sum of two masses, when in most cases, invariant mass is not linear, you can't add two masses and conserve the sum.
I am not sure what you are asking.
E=T+2Mc^2 is just a definition of T. It is appropriate to use the sum of the masses there because E=2Mc^2 when T=0.
In E^2=(pc)^2+(Mc^2)^2, the M is the mass of one proton.
  • · Replies 21 ·
  • · Replies 16 ·
  • · Replies 0 ·
  • · Replies 31 ·
