Calculate pH of Buffer Solution After HCl Added
  • Thread starter Thread starter lizzyb
    Buffer Hcl Ph
The pH of a buffer solution prepared by mixing 600.0 ml of 0.600 M HClO and 400.0 ml of 1.00 M NaClO is calculated after the addition of 40.0 ml of 3.00 M HCl. The initial concentrations of HClO and ClO- are determined to be 0.36 M and 0.4 M, respectively. After the addition of HCl, the concentration of H+ ions is recalculated to be 1.15954 X 10^-5 M, resulting in a final pH of 4.936. The discussion emphasizes the use of the Henderson-Hasselbalch equation for simpler calculations in buffer solutions.
  • Understanding of buffer solutions and their components (HClO and NaClO).
  • Knowledge of acid-base equilibrium and the concept of Ka.
  • Familiarity with the Henderson-Hasselbalch equation.
  • Basic stoichiometry for acid-base reactions.
  • Study the Henderson-Hasselbalch equation in detail for buffer calculations.
  • Learn about the dissociation constants (Ka) of weak acids and their implications.
  • Explore the effects of strong acids on buffer solutions and their pH changes.
  • Investigate the preparation and properties of different buffer solutions.
Chemistry students, laboratory technicians, and anyone involved in acid-base chemistry or buffer solution preparation will benefit from this discussion.
lizzyb
Question
A buffer solution is prepared by mixing 600.0 ml of 0.600 M HClO and 400.0 ml of 1.00 M NaClO. Calculate the pH of the solution after 40.0 ml of 3.00 M HCl is added to the buffer. For HClO, Ka = 3.0 X 10^-8.
Work so Far
Code:
  A buffer solution os prepared by mixing 600.0 ml of 0.600 M HClO and
  Ka = 3.0 X 10^-8.
  Work so Far:
  Initial Concentration of the Buffer Solution:   Now NaClO dissolves to completion so we have an initial
   concentration of ClO:
                   1 M * .4 L
   [ClO]_initial: ------------- = .4 M
                   (.6 + .4)L                    .6 M * .6 L
   [HClO]_initial: ------------- = .36 M
                    (.6 + .4)L    HClO     <--->    H+ +    ClO-
    .36               0       .4          initial
     -x               x        x          change
   .36-x              x      .4+x         equilibrium              x(.4+x)
    so Ka =  --------- ==> x = 1.206 X 10^-5
              (.36-x)
    which is [H+] (its concentration) and for ClO-,
    its new concentration is .400012 in 1 Liter,
    thus there are .4 moles of ClO now.
  After HCl is added:
    Moles of HCl added: 3.00M * .04 L = .12 moles
    These .12 moles will react with the .4 moles of ClO
    and will be used up so there will be no change in
    the number of moles of H+.
    There is, however, a change in concentration. For if
    we have a concentration of 1.206 X 10^-5 M for H+,
    then our new concentration is:
                      -5
            1.206 X 10    * 1 L                -5
    [H+] = --------------------- = 1.15954 X 10
            (1 + .04) L
    pH = -log([H+]) = 4.936
does this look right to you?
I am not sure if you are not overcomplicating things. These questions are usually solved simply assuming stoichiometrical reaction between strong acid and conjugated base present in the solution. This way you calculate amounts of acid and conujgated base and you put them into Henderson-Hasselnbalch equation. That's all.
Borek
11K
  • · Replies 22 ·
  • · Replies 16 ·
