Newton's Law of Gravitation vs. Gravitational Potential Energy
The discussion clarifies the distinction between two equations for gravitational potential energy: PEG = G(m1m2/r) and PEG = mgh. The first equation applies to large masses and varying distances, while the second is an approximation used near the Earth's surface. The potential energy expression includes a negative sign, indicating that potential energy decreases as masses approach each other. The approximation for PEG near Earth's surface simplifies to mgh, where g is approximately 9.8 m/s2.
  • Understanding of gravitational force and Newton's Law of Gravitation
  • Familiarity with the concept of potential energy
  • Basic knowledge of calculus for approximations
  • Awareness of spherical mass distributions
  • Study the derivation of gravitational potential energy equations
  • Learn about the implications of the negative sign in potential energy
  • Explore the concept of gravitational fields and their effects
  • Investigate the differences between classical mechanics and general relativity
Students of physics, educators teaching gravitational concepts, and anyone interested in understanding the applications of gravitational potential energy in real-world scenarios.
AznBoi
I'm confused about the two equations:
[tex]PE_{G}=G\frac{m1*m2}{r}[/tex]
[tex]PE_{G}=mgh[/tex]
When do you use either of these equations? Can these two equations be used interchangeably or not? Also, I think I remember reading somewhere that you need to use the 1st equation when the problem involves large masses and the 2nd equation when the problem is just talking about things on Earth.
Does anyone mind explaining when to use each of these equations and when not to? Why does it matter? Thanks.
The potential energy of two (spherical) masses a distance r apart actually contains a minus sign such that the closer the two masses are the less potential energy they have. You might know that you can freely add a constant to this expression as only differences in potential energy are observable.
[tex]-G \frac{m_1 m_2}{r}[/tex]
When close to the Earth's surface (r=R+h, with R the radius of the eart and h the height above the Earth's surface) you can approximate
[tex]-1/r \approx -\frac{2}{R} + \frac{R+h}{R^2} = -\frac{1}{R} + \frac{h}{R^2}[/tex]
Using this in the above expression for the potential energy (with m_2 = M is the Earth's mass) we get
[tex]G \frac{m M h}{R^2}[/tex]
plus some constant that can be ignored (as remarked above). Now, calling the factor
[tex]g \equiv G \frac{M}{R^2} \approx 9,8 m/s^2[/tex]
we get the second expression for the potential energy near the Earth's surface:
[tex]mgh[/tex]
So concerning your question, the second expression you quote is an approximation of the first (more general) expression. It is a valid approximation only close to the surface of some mass where the approximation I made in the above derivation is applicable.
  • · Replies 20 ·
