What it exactly asks i this question?
  • Thread starter Thread starter oahsen
The problem involves a heat-seeking particle that moves in the direction of maximum temperature increase, described by the temperature function T(x,y) = -(e^-2y)*(cosx). The task is to find an equation y=f(x) representing the particle's path starting from the point (π/4, 0).
  • Participants discuss the meaning of y=f(x) in the context of the particle's path and question how to relate the direction of maximum increase to the path of the particle. There are attempts to clarify the gradient vector and its implications for the particle's movement.
Some participants are exploring the relationship between the gradient and the path of the particle, while others are attempting to clarify the mathematical representation of the particle's motion. There is a recognition of the complexity involved in relating the derivatives and the parametrization of the path.
There is some confusion regarding the notation and the initial conditions provided in the problem, particularly concerning the treatment of time in the parametrization of the path.
oahsen
a heat seeking particle has the property at any point (x,y) in the plane it moves in the direction of maximum temperature increase. If the temparature at (x,y) is T(x,y)=-(e^-2y)*(cosx), find an equation y=f(x) for the path o a heat seeking particle at the point (pi/4,0)
I did not completely understood the problem. What is y=f(x) exactly? Is it a linearizaton at (pi/4,0) or such a thing?
It's the y coordinate of the particle's path. They are saying that you can find a function f(x) such that when the particle has horizontal coordinate x, then its vertical coordinate is y=f(x).
First, you should answer this. Given a function f(x,y), what is the direction of maximum increase? And if we know that a particle is always moving in the direction of max increase, how does this relate to the path of the particle?
I know that it maximum increases at the direction of
((e^-2y)*sinx) i + (e^-2y)*2cosx)j (the direction of gradient vector). However, how can ı relate it with a path?
The gradient will actually be (-(e^-2y)*sinx) i - (e^-2y)*2cosx)j .
The gradient will be at all points tangent to the path.
I think these sentence mean something. But did not understand :cry: :cry: :cry:
Let's say the path is parametrized by time, so at time t it's located at (x(t), y(t)) = x(t)i + y(t)j. The direction it's going in is it's tangent, i.e. it's derivative, x'(t)i + y'(t)j, and you want this to equal e-2y(t)sin(x(t))i + 2e-2y(t)cos(x(t))j. So you can solve for x'(t) and y'(t) in terms of x(t) and y(t). Do some clever calculus and you'll be able to solve for y in terms of x (plus some constant, whose value you determine using the given initial conditions), which is what the problem's asking for.
I don't think so. I missed it the first time I read it too, but there's a minus sign just after the "=" when he's defining T(x,y).
I am ging nearer but still some problems. I am lost between the x'(t),y'(t),x(t),y(t)... How should I get rid of this goddamn "t" ?
I'm not going to give you the answer. Well, you can suppress the (t)'s, just keep in mind though that y'(t) is dy/dt, not dy/dx.
Oh yea I missed that initial minus sign.
10K
