Can we observe particles growing in particle accelerators?
  • Context: Graduate
  • Thread starter Thread starter Sariaht
    Black holes Holes
The discussion revolves around the concept of particles gaining mass and potentially growing in size when subjected to high energies in particle accelerators. Participants explore various ideas related to the relationship between mass, surface area, and energy in the context of particle physics.
  • Some participants propose that when a particle is split into smaller particles, the mass of the resulting particles may increase in relation to their surface area.
  • Others challenge the idea that particles can be defined by surface area, questioning how one would measure it and whether it has any relevance to mass.
  • There are claims that particles gain mass when separated due to the energy associated with gravitational potential energy, as described by E = mc².
  • A participant suggests that if the surface area of a particle increases, its mass should also increase, leading to calculations about the smallest possible particle size.
  • Some argue that the concept of mass gain is independent of surface area and is more related to the energy of the particles involved.
  • There is a discussion about whether accelerating particles could lead to observable changes in size, with references to thought experiments and the nature of protons and other composite particles.
  • One participant mentions reading about the phenomenon of particles appearing to grow in size when accelerated, prompting further inquiry into the validity of this claim.
Participants express a range of views, with no clear consensus on the relationship between mass, surface area, and energy. Some agree on the principles of mass-energy equivalence, while others dispute the relevance of surface area and the implications of particle growth.
The discussion includes various assumptions about particle behavior, definitions of surface area, and the implications of energy changes, which remain unresolved. The relationship between mass and energy in the context of particle interactions is also a point of contention.
Sariaht
A very small particle is parted in two smaller particles; one positive and one negative. Is it possible that the rise of mass of the two particles gets more and more proportional to the rise of the two particle surface the smaller the two particles get?
You're saying that an electron is actually made of two smaller particles. What's your basis for this?
Since no-one has ever measured the surface area of an electron (or any particles that might make it up) it could turn out that you are completely correct, however I'm still a little unconvinced.
Also what do you mean more and more proportional, one thing is either proportional to another or it isn't.
Lol, More or less.
If the surface area raises x procent (for really small particles that is), does the mass to?
Cause then you could calculate the size of the smallest particle existing. Also their charge possibly.
cause that must be true for really small black holes. Cant a really small compact particle be considered such? They have relatively strong fields.
Positive and negative what?
Why should the sum of the mass of the particles be greater than the mass of the original particle?
How exactly do you define the "surface area" of a small particle?
cookiemonster
Particles gains mass when they are separated (Ep = mc2)
I admit that I'm not familiar with the particle physics, but E = mc^2 isn't going to convince me that particles magically cut in half gain mass.
cookiemonster
But they do!
A mesone is cracked into two quarks, and in the crack they gain mass equall to the potential energy gained
I'll take your word for it.
Now how do you define the surface area of a particle?
cookiemonster
Within which light cannot escape. Really close to the particles center of gravity.
Some photones gets reflected when they hit glass
So you're asserting that the densities of small particles is constant.
cookiemonster
For really small particles yes.
Which quickly leads to an assertion that everything is made out of the same stuff.
Why and how?
cookiemonster
http://www.quantumnet-string.tk
Well why didn't you just say that in the first place?
cookiemonster
Oh, that's an old page, i should update it.
The thing is, if (A/a)p = (M/m)p for extremely dense objects as leptones, such can easily be found.
Cause leptones are centers of mass
Yeah, and if the universe were made of monads of with mass exactly 10^-1000 kg and they magically arranged themselves in midair in front of my eyes in a pattern that said "We are monads and we have mass 10^-1000 kg," such could easily be found. What's your point?
cookiemonster
If we are made of monads, then we are not safe.
If its true for black holes, it should be true for leptones.
Leptones are charged black holes, that cannot lose there charge, cause they are the charges. "The charge is held back by the strong force".
This is just a guess.
That's one hell of a big if-then statement there.
I'm going to sleep. Good night!
cookiemonster
Good night and sweet dreams
Imagine you have a ball bearing (if you actually have a ball bearing then you won't have to imagine and this will be a lot easier for you :P). If you take it away from the Earth's centre of gravity it will gain Gravitational Potential energy. But, the Earth is also moved away from the ball bearing's centre of gravity and so the Earth also gains GPE.
By moving apart they have gained energy and therefore they have also gained mass as E = mc2 shows us.
This also works in reverse, if you bring particles together they will all lose energy and this idea is used for making fusion reactors, it is also why the sun is so hot. (As the nuclei being formed become larger and larger they give out less and less energy and eventually the fusion process takes in energy, that's when you start splitting the nuclei back up again in nuclear fission).
The mass change therefore has nothing to do with surface area of the particles and everything to do with the mass of the particles. Density does not affect any thing either.
Everyone knows you are right, since you're not left.
What?
Nothing you said proved me wrong.
If mass is dependent on energy and it can be clearly demonstrated, then it should be plain to see that the mass doesn't depend on surface area. If you take a ball bearing into space, does it's surface area increase?
Perhaps the procentual area change is proportional to the procentual mass change for a very small ball called particle splitting into two.
We are not talking balls here.
I was just using a ball bearing as an example.
Do you realize though that in your theory if you accelerate an electron enough it may become bigger than a proton, an atom and even bigger things. You're saying that if you accelerate something small to a high enough velocity, eventually you will be able to see it.
This doesn't seem right to me somehow. I read a thought experiment somewhere, it went a little like this: Imagine you were in a box that you couldn't see out of and you were floating through space. You have all the scientific equipment you could ever need but there would be no way in which you could determine your speed since there is no reference point by which to judge.
In your theory, it would be possible to determine the speed at which you are traveling by simply measuring the diameter of a hydrogen nucleus.
Actually (or so I've read) particles do grow when they are accelerated.
Protones are two bigg to participate in the mind experiment, sort'a.
  • · Replies 108 ·
22K
  • · Replies 67 ·
  • · Replies 31 ·
  • · Replies 32 ·
