| Thread Closed |
Complex numbers question. |
Share Thread |
| Apr16-07, 06:08 PM | #1 |
Express -i in polar form, using the principal value of the argument. 2. Relevant equations modulus = [tex]\sqrt{a^2 + b^2}[/tex] [tex]\theta[/tex] = arg(0 - i) 3. The attempt at a solution Well, the complex number is 0 -i. a = 0, b = -1 so: [tex]r = \sqrt{0^2 + (-1)^2}[/tex] which comes out to be 1. But for the argument, [tex]\theta[/tex] comes out to be: [tex]\tan\theta = \frac{-1}{0}[/tex] Ummm...where do we go from here?! Also, err, what IS the principal argument of the argument? I mean, it seems to be that the value of [tex]\theta[/tex] changes depending not where on the CAST diagram it is, but on where in the Argand diagram the complex number turns out to be...but, err, not always. Like, if it lies in the fourth quadrant, you don't do 360 - [tex]\theta[/tex]... |
| Apr16-07, 06:48 PM | #2 |
Mentor
The argument of a complex number x+iy is only tan(y/x) if neither x nor y is zero.
You can find the argument of -i by simply considering the argand diagram. Where does -i lie on the argand diagram? When you plot this, it should be obvious what the argument is. Note that the principal argument, is a value between -pi and pi. (or -180 and 180 degees) |
| Apr16-07, 06:59 PM | #3 |
Thanks for this. The exercises I have been doing on complex numbers have all asked for the principal argument, and some of the answers are not between [tex]\pi[/tex] and -[tex]\pi[/tex], such as 239.04 degrees.
Okay, err, I've plotted -i on the argand diagram...-i is at "-1"...I'm really not getting it here... |
| Apr16-07, 07:04 PM | #4 |
Mentor
| Apr16-07, 07:07 PM | #5 |
Mentor
Some alternatives are
| Apr16-07, 07:11 PM | #6 |
its 1 e^ {-I * Pi/2} ?
| Apr16-07, 07:13 PM | #7 |
Mentor
... please don't simply give out answers to homework questions.
| Apr16-07, 07:29 PM | #8 |
Ah, thanks for that. I'm confused but I kinda understand the answer...
| Apr17-07, 06:22 AM | #9 |
Since you say some, at least of the answers are in degrees, between 0 and 360 degrees, start at the positive real axis and measure the angle counterclockwise to the negative y-axis. You should see that the angle is a multiple of 90 degrees.
| Apr17-07, 08:06 AM | #10 |
Yeah, thanks. I'm just not sure, like...one of the answers to one of the questions was -7.15 degrees...and how can that be, if you're meant to measure it counterclockwise from the positive real axis? Sigh.
| Thread Closed |
Similar discussions for: Complex numbers question.
| Complex numbers, Homework Question. | Precalculus Mathematics Homework | 3 | ||
| complex numbers help | Differential Equations | 2 | ||
| Complex Numbers | Calculus & Beyond Homework | 9 | ||
| Complex numbers question | Precalculus Mathematics Homework | 2 | ||
| Geometry Question - Complex numbers & triangles | General Math | 1 | ||
