How to prepare the mixture of inorganic material
This discussion focuses on the preparation of a mixture of three inorganic materials: tungstosilicic acid, aluminium oxide, and silica oxide. It is established that pre-treatment is not strictly necessary for mixing these materials, but using a vibratory mill can enhance the intimacy of the mixture. For solid-state chemistry applications, mixing in a mortar followed by heat and pressure processing is recommended, with potential regrinding and pellet reforming as needed to achieve desired results.
  • Understanding of inorganic chemistry principles
  • Familiarity with solid-state processing techniques
  • Knowledge of vibratory milling equipment
  • Experience with heat and pressure treatment methods
  • Research the operation and applications of vibratory mills
  • Explore solid-state chemistry techniques for material mixing
  • Learn about the effects of heat and pressure on inorganic materials
  • Investigate methods for regrinding and pellet reforming
Chemists, materials scientists, and engineers involved in the preparation and processing of inorganic materials will benefit from this discussion.
violeta
i had a question where i want to mix three diferent inorganic material which are tungstosilicic acid, aluminium oxide and silica oxide.. Can i mixed the three inorganic material without pre-treatment?:confused:
wat is the suitable process to prepare a mixture of this inorganic material??
Chemistry news on Phys.org
Why would you need to pretreat these to mix them? If you want to intimately mix them, you might want to use a vibratory mill. If you want to do some chemistry (in the solid state), you might merely mix them in a mortar, subject them to the processing conditions (usually heat/pressure), regrind the result and reform the pellet and repeat the treatment conditions. Rinse, repeat as required?
  • · Replies 16 ·
10K
  • · Replies 19 ·
11K
