How Does White Light Affect Double Slit Interference Patterns?
  • Thread starter Thread starter aquabum619
    Slit
The discussion revolves around the effects of white light in the context of the double slit experiment, particularly in comparison to monochromatic light and its interference patterns.
  • Participants explore the differences between patterns produced by white light and monochromatic light, questioning the nature of white light and its implications for interference.
Some participants have provided insights into how multiple wavelengths might affect the observed patterns, while others are questioning the definition of white light and its role in interference. The discussion is ongoing with various interpretations being explored.
There is some confusion regarding the definition of white light and its relation to interference, with participants discussing the implications of using light of a single wavelength versus a spectrum of wavelengths.
aquabum619
How would white light in the double slit experiment be different from the pattern of a normal monochromatic diffraction?
No idea
Light of a single wavelength makes a certain type of pattern. If many different wavelengths are present at the same time, you should observe all those individule patterns superimposed. Think about what that will look like.
So is white light defined as "light from a single wavelength?" If this is so, there will be no interference and light through the slits would never interfere, right?
"white light" is an expression for light of all visible wavelengths. Light of a single wavelength will have a specific color (to our eye). Light of a single color produces interference patterns. In fact that is usually what you see in textbooks; a pattern of interference fringes due to a laser beam (single wavelength) passing through two narrow slits. To form an interference pattern, something must be interfering with something else, but it is not one color of light interfering with another.
