Thread Closed
Transverse Waves
Share Thread Thread Tools
Apr18-07, 07:25 PM   #1
Question
Transverse Waves
Please help!!!
Having a little difficulty with a homework question and concept
y = 2.28sin(0.0276pi x + 2.42pi t)
Find the amplitude, wavelength, frequency, speed and maximum transverse speed.
3. The attempt at a solution
Definitely correct answers
A = 2.28cm
Wavelength = 72.46 cm
Frequency = 1.21 Hz
Questionable answers
Speed = 87.68 cm/s
Max transverse speed = ??????
Reasoning
The speed should be w/k which would give 2.42pi/0.0276pi = 87.68 cm/s
The max transverse velocity though....would that be when the trig function of cos is equal to 1 in this equation u = -wAcos(kx-wt) ????
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Apr18-07, 10:19 PM   #2
Homework Helper 2012
Recognitions:
Homework Helper Homework Help
The speed is correct. Transverse speed is when dy/dt is a max. I think you are pretty much nailing that as well.
Apr19-07, 03:04 AM   #3
Apologies...still not quite sure.....would I use the w and A i know multiplied with cos(kx-wt) to get my answer.....so if cos(kx-wt)=1, then max transverse speed would be -wA???
Apr19-07, 03:59 AM   #4
Recognitions:
Transverse Waves
If your displacement function is a sin wave, it's not possible that your velocity "function" be a constant of 87.68cm/s as you calculated. Your speed would be a function as well.
As you know, velocity is the change of displacement over time (i.e. dy/dt), so by differentiating the function for y, you will get a the velocity function (which in this case is a cosine function). That cosine function will allow you to calculate the speed at any location x and time t.
To calculate the maximum speed, we take a look at the velocity function. If you do your calculus right, the equation should look something like:
v = B cos (Cx + Dt)
There is an infinite possibility for the values of x and t, so we can assume that hthe cosine can return any value. The maximum value however of a cosine function is 1. So what does that tell you about your maximum velocity?
Apr19-07, 07:51 AM   #5
Recognitions:
Quote by croyboy View Post
Yes. Except I'd call the maximum speed +wA. Why would you say minus?
Apr19-07, 09:26 PM   #6
Thanks much....makes a lot more sense.....appreciate the help
Thread Closed
Thread Tools
Similar Threads for: Transverse Waves
Thread Forum Replies
On The Nature of Transverse Waves General Physics 0
Superposition Of Transverse Waves. Classical Physics 2
Transverse waves Introductory Physics Homework 0
transverse waves Advanced Physics Homework 1
Transverse Waves Help Introductory Physics Homework 0
