Continuous random variable={-b-(b^2-4ac)^.5}/(2a)=x?
The problem involves a continuous random variable representing weekly grain demand at a factory, characterized by a specific probability density function. The task is to determine the quantity of grain needed to meet 98% of the demand based on this distribution.
  • Exploratory, Assumption checking
  • Participants discuss the integration of the probability density function and the resulting values obtained from the quadratic formula. There is a focus on understanding why one of the calculated answers is preferred over the other.
The discussion is ongoing, with participants exploring the implications of the domain of the probability density function and questioning the validity of the answers derived. Some guidance has been offered regarding the constraints of the function's domain.
Participants are examining the specific values of x that are permissible within the context of the problem, as defined by the probability density function.
inv
[Solved]Continuous random variable={-b-(b^2-4ac)^.5}/(2a)=x?
A factory is supplied with grain at the beginning of ea week.The weekly demand,X thousand tonnes for grain from this factory is a continuous random variable having the probability density function given by
f(x)=2(1-x),0<x<1
0 ,otherwise
Find the quantity of grain in tonnes the factory should've in stock in the beginning of a week in order to be 98% certain that the demand in that week will be met.
*I've found 2 answers but the answer sheet only chose 1 of 'em,found by using the (-b-(b^2-4ac)^.5)/(2a)
(-b+(b^2-4ac)^.5)/(2a)
I've integrated f(x) with the lower x value and higher x value 0 and 1 respectively and got:
[2x-x^2]=0.98
0=x^2-2x+0.98
x=1.14 and 0.859
*I don't know why the answer sheet chose only the 0.859,why?
What's the domain of f in the orginal question?
Domain of f is x,domain is x and range is y.That's what u want?
No, sorry, I'll rephrase my question. The function f is only defined for certain values of x. What are these? Are both of your answers in the interval of allowed x values?
No.Only 1 of 'em're,which makes this case solved.Tq so much for making me realize.
No, the domain of a function is the set of possible values for x- and those are given in the problem.
Thanks for the reply a bunch Ivy ,bye.
