Thread Closed
Apparatus to measure volume
Share Thread Thread Tools
Apr19-07, 10:18 AM   #1
Could anyone recommend a piece of lab apparatus which will measure the volume of an irregular object? I cannot use displacement of water as the object will compress under pressure and I suspect submerging the object in water will give a different displacement from the actual volume at 1 atm.
Ideally I would use something that could measure volume optically... Anybody know of an apparatus which does that?
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> As chaos celebrates its 50th birthday, biophysicist develops a new method to visualize it
>> Novel features of helium-3 superfluidity discovered with new SQUID detector chip
>> Physics of 'green waves' could make city traffic flow more smoothly
Apr19-07, 10:31 AM   #2
Mentor
If you know its density, you could just weigh it.
Otherwise, you could use a 3-D digitizing device to digitize its outline. I've seen them in the past, but will have to do a quick search to see if I can find one. It's like a wand mounted on an articulated arm with rotary and linear encoders to pick up where the tip of the wand is.
I don't think you'll be able to do it optically in the general case. If your object is always convex, then you could probably do it optically with a laser grid projected on the object, and a TV camera picking up the image as you rotate it.
Apr19-07, 10:33 AM   #3
Mentor
Wow, I just did a google search on 3D Digitizer, and got a bzillion hits. Here's one:
http://3ddigitalcorp.com/escan.htm
They do it optically. And here's an article about doing it with a wand:
http://lear.inrialpes.fr/people/trig...os/aritaki.pdf
Apr19-07, 10:50 AM   #4
Thanks alot! that's just what i needed.
Thread Closed
Thread Tools
Similar Threads for: Apparatus to measure volume
Thread Forum Replies
Electrical Apparatus Electrical Engineering 2
Name of Apparatus to use? Chemistry 3
Please help - apparatus construction General Physics 3
i need to measure a noise. i need the volume and frequency. General Physics 8
i need to measure a noise. i need the volume and frequency. General Physics 1
