Limits - proving their equality
  • Thread starter Thread starter theriel
    Limits
The discussion revolves around proving the equality of two limits related to the mathematical constant e, specifically lim[n->0] (1 + n)^(1/n) and the definition of e as lim[n->+oo] (1 + 1/n)^n. Participants are exploring the implications of approaching limits from different directions, particularly negative infinity.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the relationship between limits as n approaches positive and negative infinity, questioning the validity of algebraic proofs. Some suggest substituting variables to facilitate the proof, while others express uncertainty about the implications of their definitions of e.
The discussion is ongoing, with various participants offering insights and alternative approaches. Some guidance has been provided regarding the use of l'Hopital's theorem, but there remains a lack of consensus on the best method to prove the limit for n tending to negative infinity.
Participants are constrained by the definitions of e they learned in class and are required to provide a mathematical proof rather than relying on graphical or numerical evidence. There is a noted concern about the implications of indeterminate forms in their calculations.
theriel
Hello!
All of us know, that the constant e is defined as:
e = lim[n->oo] (1+ 1/n)^n
I'm proving the derivative (ln(x))'=1/x and at some point I have to show that the limit:
is equal to the one previously mentioned, the definition of e. Probably I will have to think separately about n->+oo and n->-oo, but... There is still one, the most obvious question:
How can I do that? What should I start with? Or maybe it is impossible to be proved algebraicaly and all I can do is just input that limit into the calculator and see the limit?
Thank you very much for your help!
Greetings,
Theriel
Actually you are making it much harder than it really is, thank god :)
In the definition you posted, the limit is an n tends to infinity. The 1/n here therefore tends to 0. And the exponent, tends to infinity, obviously.
In the Other limit, it is just showing the same thing. As n goes to zero, the term after the 1 still approaches the same thing. And the exponent also approaches the same thing.
In general this is a neat trick, if we have a limit of n tending to infinity, replace n with 1/n, and make the n approach zero and they are equal.
Or, if it makes more sense to you, replace n by 1/x. As n goes to 0, 1/x goes to infinity.
It looks too easy as for my maths professor so I am almost sure that there was something I forgot about ;-]. Nevertheless - once again, thank you for your advice and time!
Heh, yeah, I KNEW that there would be a problem... so:
During our classes we defined "e" as:
e = lim[n->+oo] (1+ 1/n)^n
Now I have to prove (algebraically) that the limit for n tending to -oo (negative infinity) is also equal exactly e. And it is not enough to state simply that it works or I saw a graph etc... it must be a mathematical proof.
I would highly appreciate your any ideas ;-].
Thank you for help!
Take the log of the expression and prove the limit is 1 using l'Hopital.
I am not very familiar with l'Hopital theorem, so I am basing on wiki and planetmath (hopefully properly understood)
Here, according to your hint, I must prove:
lim[n->-oo] ln((1+ 1/n)^n) = 1
so I have (n->-oo):
ln ( lim(n+1)/lim(n) ) * lim(n) = 1
here, using the l'Hopital theorem (limit of f/g = limit of f'/g'):
ln (1) * lim (n) = 1
0 * (-infinity) = 1
OK, it does not look easier ;-]. Zero times infinity is undefined... Was that meant to be done this way or you thought about some other approach?
You can only use l'Hopital for 0/0 and infinity/infinity type cases. Instead of n*ln(1+1/n) - write it as ln(1+1/n)/(1/n). Now its 0/0. Now use l'Hopital.
So we have a problem #-/ When we have:
ln(1+1/n)/(1/n)
we have to differentiate ln(1+1/n). So we have to use the formula ln(x)' = 1/x. And this formula is to be proved ;-D.
Just to point it out -> my MAIN task was to prove (e^x)' = e^x. I did it using ln(x)'. Then I had to prove ln(x)' (because during our classes we proved it using e^x). I did it, however presenting e^x in different form (see previous posts). Now, I am just to prove it for -oo...
That is why I cannot differentiate that... unless I made some logical mistake...
You don't need the limit n->-infinity to prove ln'(x)=1/x. You said you'd already proved that. So I was hoping you'd be ok with just using the derivative formula now.
No no no... maybe I would post you my whole problem, it will be easier to find some solution? By the way, thank you for your help and time, sincerely...
1.I proved e^x using ln(x)', chain rule, (x)'
2.I had to prove ln(x)', the final step:
1/x * ln (lim [n->0] (1+n) ^ (1/n) ) ---by def. of e --- 1/x * ln(e) = 1/x
hence, ln(x)' = 1/x
To make the proof ln(x) complete I was to prove that lim [n->0] (1+n) ^ (1/n) is equal to e.
Changing the first formula into:
wasn't a big problem. However, there was one difference between my definition and the one we learned about. So I am to prove that the limit holds for n->-oo ;-].
I hope I explained my problem clearly... I am proving a few things in a chain and that is why I cannot use any of them at any steps (hence no derivative of e^x, ln(x) and so on)
You are welcome for the help! But I'm still not quite catching at what point you need to prove the n->-infinity part. What is there about your proof of the derivative property that makes you need both signs?
My proof assumes that e=lim[n->oo] (1+ 1/n)^n (hence, for n tending to both +,- infinity) And, theoretically, I only know that e=lim[n->+oo] (1+ 1/n)^n . And that makes the problem ;-].
Errr...
So, what you'd like to ask is to use:
[tex]\lim_{x \rightarrow \fbox{+ \infty}} \left(1 + \frac{1}{x} \right) ^ x = e[/tex]
to prove that:
[tex]\lim_{x \rightarrow \fbox{- \infty}} \left(1 + \frac{1}{x} \right) ^ x = e[/tex], right?
Ok, so let t = -x, so [tex]x \rightarrow - \infty \Rightarrow t \rightarrow + \infty[/tex], the whole expression be comes:
[tex]\lim_{x \rightarrow \fbox{- \infty}} \left(1 + \frac{1}{x} \right) ^ x = \lim_{t \rightarrow \fbox{+ \infty}} \left(1 - \frac{1}{t} \right) ^ {-t} = \lim_{t \rightarrow \fbox{+ \infty}} \frac{1}{\left(1 - \frac{1}{t} \right) ^ {t}}[/tex]
[tex]= \lim_{t \rightarrow + \infty} \frac{\left(1 + \frac{1}{t} \right) ^ {t}}{\left(1 - \frac{1}{t} \right) ^ {t} \left(1 + \frac{1}{t} \right) ^ {t}}[/tex]
[tex]= \lim_{t \rightarrow + \infty} \left( \frac{1 + \frac{1}{t}}{1 - \frac{1}{t}} \right) ^ t \frac{1}{\left(1 + \frac{1}{t} \right) ^ {t}}[/tex]
[tex]= \frac{1}{e} \lim_{t \rightarrow + \infty} \left( \frac{1 - \frac{1}{t} + \frac{2}{t}}{1 - \frac{1}{t}} \right) ^ t[/tex]
[tex]= \frac{1}{e} \lim_{t \rightarrow + \infty} \left( 1 + \frac{\frac{2}{t}}{1 - \frac{1}{t}} \right) ^ t[/tex]
[tex]= \frac{1}{e} \lim_{t \rightarrow + \infty} \left( 1 + \frac{2}{t - 1} \right) ^ t[/tex]
[tex]= \frac{1}{e} \lim_{t \rightarrow + \infty} \left( 1 + \frac{1}{\frac{t - 1}{2}} \right) ^ t = ...[/tex]
You should be able to go from here, right? :)
Yeah, I should be able... but ;-]
I think I have missed something or there is something basic I cannot think about...
In your calculations we have to prove now that the limit is equal to e^2 (to make the whole result equal to e). We may:
- use t=-x again, however (after having done some calculations) it gives us nothing.
-make the same denominator, which gives us:
1/e * lim [t->oo] ((t+1)/(t-1))^t.
Nope, why should you make the substitution t = -x? When [tex]t \rightarrow + \infty \Rightarrow x \rightarrow - \infty[/tex], and you cannot use the limit: [tex]\lim_{\alpha \rightarrow + \infty} \left( 1 + \frac{1}{\alpha} \right) ^ \alpha = e[/tex] to complete your problem.
1/e * lim [t->oo] ((t+1)/(t-1)).
The limit is equal to 1, so the total value is 1/e... And it should be e. #-/.
The limit is not 1. You should note that [tex]1 ^ \infty \neq 1[/tex], it's one of the Indeterminate Forms.
Ok, big hint of the day. :)
We have:
And, we also have that:
[tex]\lim_{x \rightarrow - \infty} \left(1 + \frac{1}{x} \right) ^ x = \lim_{t \rightarrow + \infty} \left(1 - \frac{1}{t} \right) ^ {-t} = \frac{1}{e} \lim_{t \rightarrow + \infty} \left( 1 + \frac{1}{\frac{t - 1}{2}} \right) ^ t[/tex]
Now, if you let [tex]\alpha = \frac{t - 1}{2}[/tex], then when [tex]t \rightarrow + \infty[/tex], you also have: [tex]\alpha \rightarrow + \infty[/tex], right?
Now, do some little manipulation, and change t to [tex]\alpha[/tex], you'll arrive at the correct result in no time. :smile:
Try this argument on for size. According to my reference e^x is defined as lim[n->infinity](1+x/n)^n.
So 1/e=lim[n->infinity](1-1/n)^n=lim[n->-infinity](1+1/n)^(-n)=
1/lim[n->-infinity](1+1/n)^n.
So 1/e is equal to 1/(your limit). So your limit=e.
Yeah, I forgot about ^n in the previous approach.
Thank you very much for your help and hint! ;-] Soo... I have:
e * lim[A->+oo] (1 + 1/A)
Is the limit of 1/inifinity indiscussably equal to zero or I may expect another task from my teacher to prove it ? ;-D.
Err... He only knows that:
[tex]\lim_{n \rightarrow + \infty} \left( 1 + \frac{1}{n} \right) ^ n = e[/tex], we hasn't covered what ex is... :rolleyes:
Hurray, you get it correctly. The limit: [tex]\lim_{x \rightarrow \infty} \frac{1}{x} = 0[/tex] is well-know, hence, you don't have to "re-prove" it.
Congratulations. :smile:
Thank you both very much for your help! It was also a pretty good lesson for me ! ;-]
Greetings,
Theriel
