Optical Phonons and Monatomic Model
The discussion revolves around the absence of optical phonons in the dispersion curve for a one-dimensional monatomic chain of atoms. Participants explore the characteristics of optical and acoustic phonons, particularly in relation to atomic mass and charge differences.
  • Conceptual clarification, Assumption checking, Problem interpretation
  • The original poster attempts to understand why optical phonons cannot exist in a monatomic chain, considering the requirement for different charges and the nature of oscillations. Some participants discuss the conditions under which optical phonons arise, including the necessity of an induced dipole moment and the implications of mass symmetry.
The discussion is ongoing, with participants providing insights into the conditions for optical phonons. There is a recognition of the complexity involved in transitioning from a diatomic to a monatomic model, and some confusion remains regarding the implications of mass equivalence on phonon behavior.
Participants note that the spacing in the diatomic model differs from that in the monatomic model, which may affect the interpretation of phonon branches. There is also mention of algebraic simplifications that lead to confusion about the behavior of the phonon curves.
WolfOfTheSteps
Explain why there is no optical phonon in the dispersion curve for the one-dimensional monatomic chain of atoms.
I am completely confused. I know that optical phonons get their name because when an array of 2 atoms of different charge oscillate they are eloctramagnetically active and can absorbe or emit infrared radiation.
So I could say optical phonons are impossible for monatomic chains because you would need two atoms of different charge to get phonons.
But, I think that is wrong. Because elsewhere I read that optical phonons are described by oscillations about a center of mass, while acoustic phonons are described by a translation of the center of mass. This must imply that monatomic chains cannot have oscillations about the atom pair's centers of mass. So now I'm thinking there must be some reason why two atoms of the same mass cannot oscillate about their center of mass...
But I have no idea what that reason would be! Just imagining two balls connected by a spring, it seems that they can oscillate about this center.
Any help would be greatly appreciated!
A phonon branch is optical if its w-k curve intersects the w-k curve of a photon.
The photon has w/k=c, so w=ck. Essentially that's just a vertical line in an w-k graph, so any phonon branch that has w not equal to 0 as k-> 0 will be optically active.
Optical phonons are seen when there is an induced dipole moment, i.e. when two masses of different charge oscillate out of phase
That's just the problem. When I use my book's equation for the diatomic model, and make the masses the same, (Essentially reducing the diatomic model to monatomic... this is what a hint to a follow up problem says to do) I get two curves, one of which goes to 0 as k->0 but the other goes to a maximum at k->0. This is what I'm working with:
[tex]\omega_{\pm}^2 = C\left(\frac{M_1 + M_2}{M_1M_2}\right)\left[1 \pm \sqrt{1 - \frac{2M_1M_2}{(M_1+M_2)^2}(1-cos(ka))}\right][/tex]
If I let [itex]M_1=M_2=M[/itex] and do a good bit of algebraic simplification, I eventually get the following two functions:
[tex]\omega_- = \sqrt{\frac{4C}{M}}\left|sin(\frac{ka}{4})\right|[/tex]
and
[tex]\omega_+ = \sqrt{\frac{4C}{M}}\left|cos(\frac{ka}{4})\right|[/tex]
But [itex]\omega_+[/itex] is a cosine, so it is maximum at k=0!
What the heck?? I am completely confounded. Do you have any idea what I'm doing wrong?
Thanks again.
the spacing for the diatomic model is double that of the mononatomic model, so just making M1=M2 does not work. (double spacing in real space -> half spacing in reciprocal space)
11K
  • · Replies 0 ·
