Very simple double slit question.
  • Thread starter Thread starter linuxux
    Double slit Slit
The discussion focuses on calculating the slit separation in a double-slit experiment using 500 nm light. The distance from the first to the tenth nodal line is given as 5.0 cm, with the screen located 3.0 m away from the slits. The correct order of the tenth nodal line is identified as 9, not 10, due to the central fringe being the zeroth order. The relevant equation for determining the slit separation is derived from the double-slit interference formula.
  • Understanding of wave-particle duality in physics
  • Familiarity with the double-slit experiment
  • Knowledge of interference patterns and fringe orders
  • Basic algebra for manipulating equations
  • Review the double-slit interference formula for calculating slit separation
  • Learn about fringe spacing in interference patterns
  • Explore the implications of wavelength on interference patterns
  • Investigate the effects of slit width on diffraction and interference
Students studying physics, educators teaching wave optics, and anyone interested in experimental physics and interference phenomena.
linuxux
500 nm light passes through 2 slits. Nodal lines are produced 3.0 m away. the distance from the 1st to 10th nodal line is 5.0cm. what is the slit separation?
What equation do i use here?
is it this:
http://www.studyphysics.ca/20/unit4/wavemodel/doubleslit/note_files/image015.gif
l = wavelength of light used (m) = 5 x 10^-7
x = distance from central fringe (m) = .05m
d = distance between the slits (m) = ?
n = the order of the fringe = 10
L = length from the screen with slits to the viewing screen (m) = 3.0m
Correct, except I think that the "order" should be 9. The first line forms with no difference at all, so its order is 0, and the "order" of the 10th line is therefore 9.
thanks, that's the part i was confused about.
11K
11K
