How does a 240 volt circuit work in devices like motors and heating elements?
  • Thread starter Thread starter astranine
    Voltage
The discussion revolves around the functioning of a 240 volt circuit in devices such as motors and heating elements. Participants explore the nature of current flow, the role of voltage phases, and the comparison to other electrical systems.
  • One participant notes that a 240 volt circuit requires two 120 volt legs that are 180 degrees out of phase, questioning whether this phase difference facilitates current flow and power production.
  • Another participant compares the circuit to two batteries in series, suggesting that the neutral acts as a connection between the two, although acknowledging the difference between DC and AC systems.
  • A participant expresses confusion about how the center tap functions within the circuit, linking it to the phase difference and potential differences during current reversal.
  • One reply advises hands-on experimentation with a step-down transformer to clarify concepts, while cautioning against the idea that each wire serves as both a hot and neutral wire, emphasizing the distinct roles of the wires in the circuit.
Participants express uncertainty regarding the role of the center tap and the nature of the wires in the circuit. There is no consensus on the explanations provided, and multiple viewpoints remain regarding the functioning of the 240 volt circuit.
Participants acknowledge limitations in their understanding and the complexity of the topic, with some expressing that even professionals in the field have provided unclear answers.
astranine
I have been trying to understand how 240 voltage works in devices such as motors or heating elements I know that current needs a complete path to flow to produce power and in the typical 120 volt circuit the common is what completes the path. In a 240 volt circuit nothing more than two 120 volt legs are needed to make the motor or heating element work. I understand that the two 120 volt legs are 180 degrees out of phase. Is it the push-pull action between the two out of phase 120 volt legs which allows current to flow through the device and produce power or work? Just curious and can't seem to find the answer anywhere. Thanks!
Think of it as 2 batteries in series. The neutral is the connection between the 2 batteries. The 2 hot wires are the ends of the batteries. Of course, the battery example is DC where the 240 volt circuit is not. The neutral is a center tap on a transformer.
Hi Aveagesupernova. Thanks for your reply. I'm not sure I understand how the center tap becomes part of the circuit. Is this possible because of the 180 degree phase difference between L1 and L2 and the resulting potential difference as the current reverses making each line a neutral as well as the hot wire?
I have asked two electrical contractors this same question and both were unsure.
Thanks!
Try to get your hands on a small step down transformer with a center tap. I think some hands on work could clear things up for you. Naturally, be careful when working with the primary side connections. I wouldn't say each wire is both a hot and a neutral. That is definitely incorrect. As one leg goes positive with respect to neutral (center tap) the other is going negative. So this means the the voltage between the ends (2 hot wires) is always double the voltage between the neutral and hots. Same thing as the battery example I gave earlier.
  • · Replies 18 ·
  • · Replies 77 ·
9K
