Determine the values of a and c on a line.
  • Thread starter Thread starter ND3G
    Line
The problem involves determining the values of variables a and c for a point on a line defined by parametric equations. The subject area includes vector equations and coordinate geometry.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • The original poster attempts to find the values of a and c by substituting the known point into the line's equations. Some participants question the steps needed to isolate a and c from the equations.
Participants have engaged in exploring the relationships between the variables and the equations of the line. Some guidance has been offered regarding the substitution of values into the equations, and multiple interpretations of the approach have been discussed.
There is a focus on the specific values of a and c that correspond to the point (a, 2, c) on the line, with some participants referencing the parametric form of the equations. The clarity of the problem setup and the definitions of the variables are under consideration.
ND3G
A line is defined by the equations x = 3-4t, y = 8t, and z = 6+t
a) Determine the vector and symmetric equations of the line
b) Determine the values of a and c if the point (a, 2, c) lies on the line.
I have part a) solved: (x,y,z) = (3,0,6) +t(-4,8,1)
(3-x)/4 = y/8 = z-6/1
I am a little unclear has to how I would solve for a and c though in part b)
y-2/8 = a-x/4 = z-c/1 but I am not sure where to go from there...
At the point [tex](a,2,c)[/tex], what is the value of y?
y = 2, so 2/8 = 1/4
therefore, 3-x/4 = z-6/1 = 1/4
(2, 2, 25/4) I think I got it. Thanks
ND3G said:
y = 2, so 2/8 = 1/4
Yup. Correct. Or you can also use its parametric equation to solve the problem.
When y = 2, that means 8t = 2 ~~> t = 1 / 4
Sub t = 1 / 4 in x, and z, we have:
[tex]x = 3 - 4t = 3 - 4 \times \frac{1}{4} = 2[/tex]
[tex]z = 6 + t = 6 + \frac{1}{4} = \frac{25}{4}[/tex], so the coordinate of the point is:
[tex]\left( 2; \ 2 ; \ \frac{25}{4} \right)[/tex], so a = 2, and c = 25/4.
  • · Replies 30 ·
