Import Proteus Schematic to Orcad for PCB Layout
  • Thread starter Thread starter nadinemaalouf
    Pcb
The discussion revolves around the process of importing a schematic file (.dsn) from Proteus into OrCAD for PCB layout. Participants share their experiences and suggestions regarding the compatibility and methods for achieving this task.
  • Homework-related
  • One participant expresses uncertainty about the possibility of importing a .dsn file from Proteus into OrCAD, suggesting the use of Capture CIS instead.
  • Another participant shares their background in PCB circuit design and mentions awaiting a response from their university professor regarding the layout process.
  • A different participant provides a method for creating a PCB layout in OrCAD, detailing the steps of generating a MNL file from the schematic and then using it in the layout process, while noting that specifications for component sizes will need to be confirmed before implementation.
  • One participant indicates they will try the suggested method for importing and designing the PCB.
Participants do not reach a consensus on the feasibility of importing the schematic directly from Proteus to OrCAD, with differing opinions and methods presented without resolution.
Some assumptions regarding software compatibility and specific steps for the PCB design process are not fully explored, and there may be limitations based on the versions of the software being used.
Individuals interested in PCB design, particularly those using Proteus and OrCAD, may find the discussion relevant for understanding potential workflows and challenges in importing schematic files.
nadinemaalouf
hello,
how can i import the schematic (.dsn file) from proteus, and use it in orcad?
thanks for your answers
i think u can't ... but i am not sure u should use the capture cis...try it
hi nadine ... i was studying pcb circuits and how to make them at home.but i stopped on the capture cis only and didn't continue the layout so i sent an email to my dr. at the university and hope he is going to respond soon...(by the way r u lebanese?)
hi nadine i work before on layout of orcad , so if u want to make out of circuit u only to make schematic for the circuit then make mnl file from schematic then brouwse from layout for this file then run it, it will make the pcp design , there are some specification done for the size components used will ask u before it implement the design
i will try that
thank you
  • · Replies 20 ·
  • · Replies 0 ·
