Why is 1 Decibel = 10 Log (Power1/Power2)?
  • Context: Undergrad
  • Thread starter Thread starter sk381
    Decibels
The discussion revolves around the relationship between decibels (dB) and Bels, specifically addressing why 1 decibel equals 10 times the logarithm of the power ratio (Power1/Power2). Participants explore the definitions and implications of these units in the context of power measurements.
  • Some participants assert that 1 Bel equals Log(Power1/Power2) and that 1 dB equals 0.1 Bel, leading to the conclusion that 1 dB equals 10 Log(Power1/Power2).
  • Others challenge the assertion that 1 Bel equals Log(Power1/Power2), stating it is not true and questioning the derivation of the relationship between dB and Bel.
  • A participant provides an example using specific power values (P1 = 1000, P2 = 10) to illustrate the calculation of power difference in Bels and dB.
  • Some participants express confusion about the definitions and relationships, seeking further clarification and examples.
  • One participant emphasizes that the key point is that Log(P1/P2) is a measurement in units of Bels, not equal to 1 Bel.
  • Another participant attempts to combine statements to derive the relationship between dB and Bel, suggesting that 1 dB equals 10 Bel, but this is met with skepticism.
Participants do not reach a consensus on the initial definitions and relationships between Bels and decibels, with multiple competing views and ongoing confusion about the implications of these definitions.
There are unresolved assumptions regarding the definitions of Bels and decibels, as well as the mathematical steps involved in deriving the relationship between them. The discussion reflects varying levels of understanding among participants.
sk381
I know that
1 Bel = Log (Power1/Power2)
and 1 decibel = 0.1 bel
then why is 1 decibel = 10 Log (Power1/Power2)
and not 0.1 Log (Power1/Power2)
Thanks
SK
Not true. See below.
It isn't.
1 dB = 0.1 Bel (this is true)
This is what Bel and dB mean:
Power difference (measured in Bels) = Log (Power1/Power2)
Power difference (measured in dB) = 10 Log (Power1/Power2)
Make sense?
Hmm.. not clear yet...
I didn't get it..
Can you give some example to further elucidate?
If:
Then:
Power difference (measured in dB) = 10 * Power difference (measured in Bels)
But you say that:
1 dB = 0.1 Bel
So I don't get it either. :wink:
Originally posted by Chen
If:
Then:
Absolutely. If you measure power in dB your answer will be 10 times bigger than if you measured in Bels.
But you say that:
1 dB = 0.1 Bel
Yep.
I'm not sure what you guys don't get.
The key point is that Log(P1/P2) does not equal 1 Bel, it is a measurement in units of Bels.
Example: Say P1 = 1000; P2 = 10;
Log (1000/10) = 2 Bels
10 Log (1000/10) = 20 dB
lol, never mind. I'm not supposed to be awake anyway.
Ok...
but then how do we arrive at the conclusion that 1 dB = 0.1 Bell
Just combine the two statements:
Power difference (measured in dB) * 1 dB = 10 * Power difference (measured in Bels) * 1 Bel.
The power difference is the same so:
1 dB = 10 Bel.
Ok...
First realize that 1 dB = 0.1 Bel by definition. (The prefix 'deci' means 1/10.)
But it all makes sense. A given power level [itex]P[/itex], measured with respect to the reference power level [itex]P_{ref}[/itex], would equal [itex]\log_{10}(\frac{P}{P_{ref}}) \b{Bel} = 10 \log_{10}(\frac{P}{P_{ref}}) \b{dB}[/itex]. So, 1 Bel = 10 dB.
1 dB = 10 Bel.
Snap out of it, Chen. You're still not quite awake. :smile:
The power difference is the same, just measured using different units.
[Log(Power1/Power2)]Bels = [10 Log(Power1/Power2)]dB
  • · Replies 39 ·
9K
  • · Replies 18 ·
