Calculating Light Intensity through Polarized Lenses | Polarization Question
  • Thread starter Thread starter KingJaymz
    Polarization
The discussion focuses on calculating the final intensity of light passing through three polarized lenses with specific angles. The initial intensity of the light is 75 W/m², and the calculation involves applying Malus's Law, which states that the intensity after passing through a polarizer is I = I₀ * cos²(θ), where θ is the angle between the light's polarization direction and the axis of the polarizer. The final intensity calculated is 2.84 W/m², confirming that the method used by the user, KingJaymz, is correct according to the example provided in class.
  • Understanding of Malus's Law in optics
  • Basic knowledge of trigonometric functions, particularly cosine
  • Familiarity with the concept of light intensity and polarization
  • Ability to perform calculations involving angles in degrees
  • Study advanced applications of Malus's Law in multiple polarizer systems
  • Learn about the effects of varying angles on light intensity through polarized lenses
  • Explore the principles of light polarization and its practical applications in photography
  • Investigate the mathematical modeling of light behavior in optical systems
Students studying optics, physics enthusiasts, and professionals in fields involving light manipulation, such as photography and optical engineering.
KingJaymz
Hello everyone. I wanted to make sure I did this problem correctly. The problem is this:
A light with an intensity of 75 W/m^2 is shone through three polarized lenses. The first lens is tilted at a 37 degree angle, the second is at a 10 degree angle and the final lens is titled by 82 degrees. Find the final intensity of the light.
So this is my work:
75 W/m^2 X 1/2 (half of the light is filtered through the first lens) X cos^2(37-10) X cos^2(82-10) = 2.84 W/m^2
Is this the proper way to do this problem? This is the way our example from class was calculated, but I was a little bit hazy on the details, so I wanted to make sure that I did the work right. Thank you all.
Yes. I didn't check your arithmetic, but your method is correct.
Thank you very much. I've been away from this stuff for so long that it makes me question my methods at times.
  • · Replies 25 ·
